Cat-M1 + GNSS Unit has no GPS GNSS option.
According to the docs page the Cat-M1 + GNSS unit supports GPS, but in UiFlow the only options are GLONASS (Russia), BEIDOU (China), GALILEAN (Europe), and QZSS (Japan), and I'm in the US and I need to use GPS.
Hello @HWTaro9
I think you can choose any of the four options as GPS is always included by default. From the SIM7080 AT command document:
AT+SGNSCFG="MODE",<mode>
0 start GPS and GLONASS constellation
1 start GPS and GALILEO constellation
2 start GPS and BEIDOU constellation
3 start GPS and QZSS constellationThanks
Felix -
@felmue Thanks! so if I don't use the block that sets what constellation it uses, it will default to just using GPS, right?
Hello @HWTaro9
I just ran below three blocks and monitored the AT commands they would send to the modem (w/o the modem actually stacked / connected to the M5Stack):
GNSS power control 'on' ->
AT+CGNSPWR=1
GNSS work mode 'GLONASS' ->AT+CGNSMOD=1,1,0,0,0
GNSS NMEA poll task ->AT+CGNSINF
This means that the AT command
AT+SGNSCFG=<MODE>
I mentioned before is not part of these three blocks.BTW: checking the work mode on my SIM7080 for the first time returns:
AT+CGNSMOD? +CGNSMOD: 1,1,0,0,0
which means GPS and GLONASS are enabled. And since this command's parameter saving mode is
AUTO_SAVE_REBOOT
I would assume that this is the default.In other words if you omit the work mode block I'd assume GPS and GLONASS are enabled by default.
Felix -
@felmue Thank you very much!
