    [WIP] M5ez Hello World.
    Scheduled Pinned Locked Moved Lessons and Guides
    15 Posts 4 Posters 34.0k Views 1 Watching
      M5ez Hello World
      M5ez is such a useful library that it provides the user with several methods to achieve the same same result.
      I will attempt to show you the different ways to make the basic Hello World app using the system.
      This first example (taken from the github page) shows you how to display Hello World using M5ez's header function.
      alt text
      This will show you how to make a Hello World project using M5ez
      The following code will creat a header on the screen with the text "Hello World".
      #include <M5ez.h>
      // put your setup code here, to run once:
      ez.begin();
      ez.header.show("Hello World");
      // put your main code here, to run repeatedly:
      delay (1000);
      Lets break this down.
      First up we call
      #include <M5ez.h>
      This tells Arduino (the IDE) to load the M5ez Library, next we call,
      ez.begin();
      Which tells the M5 to begin the M5ez app, and now we call,
      Which actually draws a blue line on the top of the screen with Hello World written in it. We can ignore the Void Loop(){} section because we are not using it, but I put delay(1000) in just to give it something to do.
      As I said above, this isn't the only way to do this. Lets try something else (thanks Rop for the example).
      Version2
      alt text
      In this example all we did was replace the delay in the loop section with the following
      ez.msgBox("M5ez minimal program", "Hello World !", "Settings");
      ez.settings.menu();
      As you can see, the original header has been overwritten because (in this case) the contents of the loop over-rides the header set-up in the
      void setup() {}
      Section.
      RopR 1 Reply Last reply Reply Quote 1
      • RopR Offline
        Rop @ajb2k3
        @ajb2k3 Maybe this is an even better Hello World program:
        #include <M5ez.h>
          ez.begin();
          ez.settings.menu();
        It shows how much M5ez does out of the box (WiFi, clock, backlight settings)...
        (I will add this to the examples...)
          I was just following your github page and this was the first thing.
          btw the delay is needed as i put it in the loop and it keeps vanishing as the screen clears and redraws.
          Changed the code to move the header into the setup section.
          the delay is just to give the loop something to do.
            Lets add an image to Hello world.
            alt text
            #include <M5ez.h>
            #include "images.h"
            ez.begin();
            ezMenu images;
            images.imgBackground(TFT_BLACK);
            images.imgFromTop(40);
            images.imgCaptionColor(TFT_WHITE);
            images.addItem(sysinfo_jpg, "Hello World");
            images.addItem(return_jpg, "Back");
            images.run();
            For this example I have imported the images.h file from the M5ez demo folder into the project. I Then add
            #include "images.h"
            which tell the IDE to compile the file into the code.
            To get the image menu to appear we need to replace our void loop with
            ezMenu images;
            images.run();
            What this does is calls the ezMenu images; instead of ez.msgBox.
            Next we set the background to black, tell the text to start 40px from the top in white.
            sysinfo_jpg calls the cpu logo and "Hello World" as in previous examples sets the caption to Hello World.
              r_255
              Is the hello world text replaceable with a variable ?
                ajb2k3 @r_255
                @r_255
                Dont know, you would have to ask rop but you can directly print the variable with one of the m5's lcd print commands.
                  r_255
                  I did try it, but failed hard...
                  thanks !
                    ajb2k3 @r_255
                    @r_255 在 [WIP] M5ez Hello World. 中说:
                    thanks !
                    What code are you using?
                    • RopR Offline
                      Rop
                      Any string that is supplied to any of M5ez's functions can also be a String variable.
                      So:
                      #include <M5ez.h>
                        ez.begin();
                        String header = "Hello World !";
                        ez.msgBox("M5ez minimal program", header, "Settings");
                        ez.settings.menu();
                      works as well as the version further above...
                        r_255
                        Okay, i am going to try, as i want a value above my slider :O)
                        Thanks !
                          @Rop I can't get my example to work, can you help?
                          I'm trying to use this image file
                          hello.h file hosted on github.
                          But when I compile and upload, the image doesn't show. Can you see what i'm doing wrong?
                          This is my code:
                          #include <M5ez.h>
                          #include "hello.h"
                          ez.begin();
                          ezMenu images;
                          images.addItem(hello_jpg, "Hello World");
                          images.run();
                          • RopR Offline
                            Rop @ajb2k3
                            @ajb2k3 If I try your hello.h, it doesn't compile because of double commas that I had to take out first. After doing that, it doesn't display an image indeed. But your image also doesn't display if I do
                            m5.lcd.drawJpg((uint8_t *)hello_jpg, sizeof(hello_jpg));
                            delay(2000);
                            In the setup() function. I don;t have the source JPG, but for now I'm assuming your JPG may be in a format that the M5Stack JPG library doesn't display, or something else is wrong with it.
                            Also: if you want the menu to have a header, you should add it in the declaration of the menu:
                            ezMenu images ("Hello World!");
                            The menu clears the screen before displaying anything when you run it. You'll rarely need to use ez.header.show if you use standard M5ez functionality.
                              ajb2k3 @Rop
                              @rop 在 [WIP] M5ez Hello World. 中说:
                              delay(2000);
                              Sorry, forgot the source jpg.
                              alt text
                              Interesting /\ the forum isn't showing the image above.
                              I think it may be the conversion to array that is causing issues. I had this before but can't remember how I solved it. I also needed to check that it wasn't just my code that was at fault (excluding the hello.h)
                              I left the header clear to give more screen room.
                              MKII?
                              alt text
                              • O Offline
                                Orthodudz @ajb2k3
                                @ajb2k3 is this issue solved yet? I am also having difficulty adding image even using SPIFFS by imageSPIFFS example.
                                  ajb2k3 @Orthodudz
                                  @orthodudz I worked it out now and currently writing up how for my handbook project.
                                  I have managed to get an image to load without m5ez using UIFlow but you will need to see the face book group for the progress.
