[closed] Micropython Jquery confusion.
I'm trying to run the following code but I seam to be missing something.
from m5stack import * from m5stack_ui import * from uiflow import * screen = M5Screen() screen.clean_screen() screen.set_screen_bg_color(0xFFFFFF) image0 = M5Img("res/default.png", x=3, y=91, parent=None) import urequests r = urequests.get('https://community.m5stack.com/api/user/ajb2k3') r_dict = r.json() image0.set_network_img_src(((str('https;//community.m5stack.com') + (r_dict['picture']))))
Nevermind I solved it with
from m5stack import * from m5stack_ui import * from uiflow import * screen = M5Screen() screen.clean_screen() screen.set_screen_bg_color(0xFFFFFF) imgrespons = None image0 = M5Img("res/default.png", x=3, y=91, parent=None) label0 = M5Label('Text', x=35, y=41, color=0x000, font=FONT_MONT_14, parent=None) import urequests r = urequests.get('https://community.m5stack.com/api/user/ajb2k3') r_dict = r.json() imgrespons = ('https://community.m5stack.com' + r_dict['picture']) label0.set_text(str(imgrespons)) image0.set_network_img_src(imgrespons)
