    M5 LAN Base with Core2 have no function on UIFlow
    5 Posts 2 Posters 6.4k Views 1 Watching
      jollawat
      I tried to program by UIFlow when connect Core2 + LAN Base but seens it's not initialize as uasual, when use same code with Core Basic + Lan Base also function.
      Error on screen siad about library is W5500 configuarion not support Core2.
      M5 Support team please help to update F/W for Core2 can support LAN base as well.
        Hello @jollawat
        works for me. Below is a simple TCP LAN server example using M5Core2 which upon connection sends the string "1234" to the TCP client then restarts.
        Note: w/o the 1 second wait I get Ethernet disconnected error.
        UIFlow firmware running on M5Core2 is: 1.9.8
          jollawat @felmue
          @felmue It's works with machine type client?
            Hello @jollawat
            yes - below are the blocks I used:
              jollawat @felmue
              @felmue Many thanks Felmue previously I'm use other F/W after use 1.9.8 it back to function.
