    Font size 10 Not functioning on V1.98
    2 Posts 1 Posters 3.9k Views
      SE
      If you use the size 10 Font with V1.98 you will get an error stating that is not defined. If you have apps that you wrote previously that used that font they will not load/function properly.
      You can test this by adding a label and setting its Font to size 10. With only the one label "Run" and you will get the error
      Scott
        SE
        This is on a Core2
