    UI Flow Software 0.8.0 Sensor problems
    12 Posts 3 Posters 22.9k Views 2 Watching
    • SkinkS Offline
      Skink
      Hello M5stack users
      Today I have the Flow Software 0.8.0 installed. And had to find out that the IR remote sensor and the Motion Sensor and the Angel Sensor version 0.8.0 does not work.
      Under Flow Software 0.7.0, all sensors work without problems.
      The M5Stack team has to look at the software again.
      So do not be surprised if the sensors react funny.
      Have already sent a message to the M5Stack Team !!
      skink
        ajb2k3 @Skink
        @skink 在 UI Flow Software 0.8.0 Sensor problems 中说:
        Hello M5stack users
        skink
        The Angle sensor does not work because the grove connector is digital only.
        You have to use jump leads to connect it to the terminals around the side of the M5stack.
        • SkinkS Offline
          Skink
          @ ajb2k3
          Have again the software UI Flow 0.8.0 installed. And again tested the sensors. Only the IO Remote Sensor is not working in the software.
          Have this as well as the other sensors connected to the Black Port (B / GPIO).
          It is only the ENV sensor connected to the port (A / I2C), that's already clear to me.
          But you can also see a cell phone camera when you connect the IO Remote Sensor to the port (B / GPIO) port in the software 0.8.0 of the infrared sensor emits no infrared light, but in the software 0.7.0! !
          Look at the pictures !!!!
          Greeting skink
          • SkinkS Offline
            Skink
            Here are the pictures ,
            Software 0.8.0 IR Remote Transmitter diode sending nothing !!
            Here Software 0.7.0 IR Remote Transmitter Diode Sends Signal !!
            Greetings Skink
              ajb2k3 @Skink
              @skink Nice capture on the signal.
              Out of curiosity (I dont have any of the sensors) any chance you can open the case and capture a photo of the internals?
              BTW pull the camera back about a foot and retake the photos!
              Also, any chance of posting the python code from the two versions?
              It is possible that something broke when they tried to fix something else.
              • SkinkS Offline
                Skink
                The sensors are from the M5GO IOT set, which I bought, in the picture you would not see much, because the boards have both sides PCB tracks.
                But there is documentation, here's the link: https://github.com/m5stack/M5GO/tree/master/hardware/schematics. There you can see, I think there is the interest as the sensors are interconnected and what was installed.
                Greeting skink
                • SkinkS Offline
                  Skink
                  The software is integrated in the UI FLow software, does not know how I can read the code from the firmware !?
                  So they are not programs of mine !!
                    ajb2k3 @Skink
                    @skink Thanks, been struggling to find those docs.
                    How have you been testing to see if the sensor is recieving?
                    Not the firmware, just the python code generated by uiflow.
                    • SkinkS Offline
                      Skink
                      Nothing to thank @ ajb2k3,
                      I first installed UIFlow 0.8.0 on the M5Stack. Then tested, then a lot on me the sensor does not send over the camera of the mobile phone.
                      Afterwards I installed UIFlow 0.7.0 on the M5Stack and lo and behold, the sensor is sending !! You can see it in both pictures !!
                      Greeting skink
                        ajb2k3 @Skink
                        @skink How are you using the sensor because I cant find any controls for UIFlow to control the sensor
                        • SkinkS Offline
                          Skink
                          @ ajb2k3
                          Install the UIFlow 0.7.0 software on your M5Stack.
                          Start the M5 stack and select with button B (App.List) then M5GO and again with button B (Run) then you select the appearing menu button C (Next) until you see the menu item Extension IR Remote, then connect the sensor and test.
                          With this program you can test all sensors of the M5Go IOT system.
                          (I have already told you the instructions for the construction of the sensors where you can find them)
                          However, you either need the M5Stack from the M5Go IOT set or the M5Stack Fire, since you need the M5Go bottom for the M5Stack that has the connection bars, but should also go with a Basic or Core M5Stack because the connection strips are nothing but the ports Here are the occupancy of the M5Go Bottom:
                          Link: https://m5stack.readthedocs.io/en/latest/product-documents/m5stack-core/m5stack_fire.html
                          Greetings Skink
                          • m5-docsM Offline
                            m5-docs @Skink
                            @skink
                            Hello, skink. Good afternoon!
                            Has your problem been solved?
                            M5Stack documentation URL
                            https://docs.m5stack.com
