    BLE with the arduino framework
    2 Posts 2 Posters 4.0k Views
      freska
      We are using the M5core2 and we want to run a BLE-based application using the Arduino programming framework. We download the library for the ESP architecture: https://www.arduino.cc/reference/en/libraries/esp32-ble-arduino/
      But, it seems that the library is not compatible with this architecture. We got the following error when initializing the library.
      ***Guru Meditation Error: Core 1 panic'ed (Interrupt wdt timeout on CPU1)
      Core 1 register dump:
      PC : 0x40096769 PS : 0x00060334 A0 : 0x800987a2 A1 : 0x3ffc8080
      A2 : 0x37735134 A3 : 0x0000abab A4 : 0xb33fffff A5 : 0x00000001
      A6 : 0x00060120 A7 : 0x0000cdcd A8 : 0x400df228 A9 : 0x3ffc81a0
      A10 : 0x3f41ef14 A11 : 0x00000069 A12 : 0x3f41f248 A13 : 0x3f41efa0
      A14 : 0x00000001 A15 : 0x00000000 SAR : 0x00000020 EXCCAUSE: 0x00000006
      EXCVADDR: 0x00000000 LBEG : 0x40092a50 LEND : 0x40092a6c LCOUNT : 0xffffffff
      ELF file SHA256: 0000000000000000
      Backtrace: 0x40096769:0x3ffc8080 0x4009879f:0x3ffc80b0 0x40098dc9:0x3ffc80d0 0x4008239d:0x3ffc80f0 0x400825d4:0x3ffc8110 0x40082639:0x3ffc8130 0x400f1a6d:0x3ffc8180 0x400f1065:0x3ffc81a0 0x400d66a2:0x3ffc81d0 0x400d1825:0x3ffc8200 0x400dd3e2:0x3ffc8250 0x40095736:0x3ffc8270
      Core 0 register dump:
      PC : 0x40015c45 PS : 0x00060434 A0 : 0x80015e4d A1 : 0x3ffcb8d0
      A2 : 0x3ffcb9e0 A3 : 0x3ffcb940 A4 : 0x4efc3e53 A5 : 0x00000008
      A6 : 0x3ffcb940 A7 : 0x3ffcb9e0 A8 : 0x3ffcb9fc A9 : 0x00000007
      A10 : 0x6a73bc23 A11 : 0xffffffff A12 : 0x00000000 A13 : 0x6a73bc23
      A14 : 0x00060220 A15 : 0x00000000 SAR : 0x0000001f EXCCAUSE: 0x00000006
      EXCVADDR: 0x00000000 LBEG : 0x4000c46c LEND : 0x4000c477 LCOUNT : 0x00000000
      Backtrace: 0x40015c45:0x3ffcb8d0 0x40015e4a:0x3ffcb8f0 0x4001606a:0x3ffcb940 0x400161b9:0x3ffcb990 0x400162a1:0x3ffcba30 0x40016889:0x3ffcbc40 0x40016c1a:0x3ffcbd70 0x40019d11:0x3ffcbdf0 0x40055b4d:0x3ffcbe10 0x4016abbf:0x3ffcbe30 0x4016b1cd:0x3ffcbe50 0x40095736:0x3ffcbe80
      Rebooting...***
      Does the M5core 2 support the BLE communication? Is there any Arduino-based library to handle the communication?
      We have tested the library with the M5stack core hardware and it run properly.
        decidable
        Hello. Not sure if you managed to get this working yet, but if not, there is a ble library that ships with M5Stack Core2 Arduino install.
        #include <BLEDevice.h>
        on my computer this was installed at this location: .//Library/Arduino15/packages/m5stack/hardware/esp32/2.0.3/libraries/BLE/src/BLEDevice.h
        Hence I did not have to install the package separately.
        I have implemented a project using this just recently using a variety of BLE technology so confident that it works on at least my copy of Core2.
        If you go to the docs link from the library link you posted (https://github.com/nkolban/ESP32_BLE_Arduino) you can see that the project has now been directly incorporated into Arduino. The lib version you may have downloaded may be out of date. You can find BLEDevice.h/BLEDevice.cpp on your machine and check against the main Arduino source.
        Hope this helps?
