    UIFlow 1.9.7
    Official Updates
    5
    6
    13.7k
    • m5stackM
      v1.9.7
      new features:
      • ZH-CN:
        • UNIT BUZZER 支持
        • MODULE COM.X GSM 支持
      • EN:
        • UNIT BUZZER support
        • MODULE COM.X support
      Bug fix:
      • ZH-CN:
        • UNIT DDS 错误修复
        • NB-IOT & DTU NB-IOT CoAP 错误修复
        • M5PAPER 图像和矩形 错误修复
      • EN:
        • UNIT DDS bug fix.
        • NB-IOT & DTU NB-IOT CoAP bug fix.
        • M5PAPER image and rectangle bug fix.
      L 1 Reply Last reply Reply Quote 1
      • G
        GertschAlt
        Could it be that the firmware update for 1.9.7 is not yet released? If so, when will this be the case? Or is there a possibility to revert the version of uiFlow to 1.9.6 which I am not aware of?
        • L
          luis @m5stack
          @m5stack
          please support MODULE COM.X LTE DATA in a next firmware release.
            Not a bug per say but more of a visual suggestion.
            The last block(Get Label Width) in the core2's LVGL Table block needs moving about 5 pixels in to light up with the other blocks.
              Can you implement the LVGL image resize routines as blocks please?
                Hi guys
                in UiFlow the IoTBaseCatM module can only be used if a SIM card has been inserted. In other words the non IoT related ports (e.g. Modbus) cannot be used w/o SIM card inserted. The reason for that is that as part of the initialization catmiot = module.get(module.CATMIOT) an AT+CPIN? command is sent every 6 seconds forever since w/o SIM card inserted the response from the SIM7080 is ERROR.
