IoT Base CATm - Core2 restarts every 3-5 min or so
 Re: Core2 keeps rebooting with PoE base I’m guessing this is probably the same/similar issue I’m having with my Core2 and the IoT CATm base? What exactly do I need to do here? Please help :)
 Hello @iamjameshannam the issue described in Core2 keeps rebooting with PoE baseis an immediate reboot cycle within a couple of seconds (and not after a few minutes). So, no, I don't think this is the same issue.Can you describe what software you are running on your M5Core2? UiFlow? Arduino? Are you running from external power or battery? Thanks
 Hello @iamjameshannam do you have a SIM card in your IoT Base CatM module? I did some testing and from within UiFlow it seems that as part of the module initialization (e.g. catmiot = module.get(module.CATMIOT)) anAT+CPIN?command is sent repeatedly (about every 6 seconds) until the module response is+CPIN: READY. Without SIM card the module response isERRORwhich means the program flow is blocked forever.Thanks
