    ghost qr code on m5paper?
    General
    4.7k
    • B
      belsonc
      Hi -
      I'm experimenting with my new m5paper, and had the idea to create a qr code so my friend will be able to use my wifi while I'm on vacation. I used uiflow/blockly to create the following code:
      from m5stack import *
      from m5ui import *
      from uiflow import *
      setScreenColor(15)
      label0 = M5TextBox(134, 414, "Text", lcd.FONT_DejaVu24, 0, rotate=0)
      lcd.clear()
      label0.setFont(lcd.FONT_DejaVu40)
      label0.setText('Wifi Info')
      lcd.qrcode('text text text', x=150, y=400, width=220, version=6)
      lcd.show()
      And I'm getting a ghost qr code, for lack of a better way to describe it. I moved the qr code once, and it only started happening following that. If anyone can help, I would appreciate it...
        M5Stack_AG
        Hi there , We appreciate your feedback! we will fix it soon!
        • D
          democrazia
          @belsonc said in ghost qr code on m5paper?:
          setScreenColor(15)
          I've the same problem.
          I've you found a solution ?
          Tkx
          • D
            democrazia
            The latest update put the gray square always under the QRcode.OK
            But why a gray square instead of the backcolor ?
