    M5stack core 2 TCPIP connection example
    PROJECTS
    5.3k
      moonbouncer
      I'm new to the M5stack,
      Trying to connect to my Wifi accesspoint and connect to a tcpip server and send some text when a button is pressed
      after the connection with the wifi AP the screen hangs and no tcpip connection is setup?
        Hello @moonbouncer
        the Init LAN block can only be used in conjunction with the LAN Module (Ethernet). Do you have a LAN Module stacked to your M5Core2?
          moonbouncer @felmue
          @felmue Thank Felix, yes i found that out after my post, is there a way to do a TCP socket client,similar to the UDP socket option in UI ?
            Hello @moonbouncer
            not that I am aware of, no. I don't see any general TCP blocks in UiFlow. You probably would need to use MicroPython directly.
