    Question about M5Stack Sim800L Module
    8 Posts 3 Posters 18.0k Views 1 Watching
      ken57093
      I'm now trying to use the sim800L Module (https://www.elektor.com/m5stack-sim800l-gsm-module).
      I want to check whether the sim card can connect to network.
      However, I cannot check whether the sim card have network function.
      I had visit different website and use tinyGSM but still can't fix the problem. Can anyone give me some tips?
      The websit I had read:
      https://www.arduino.cc/en/Guide/ArduinoGSMShield
      https://www.ayomaonline.com/programming/quickstart-sim800-sim800l-with-arduino/
        ken57093
        • RopR Offline
          Rop
          Have you read the datasheet for the modem?
          • L Offline
            LastCaress @ken57093
            I'm also trying to use this module, without success. It's one of the less documented ones :\
              ken57093 @LastCaress
              @lastcaress @Rop
              I don't know why after I upgrade the arduino from 1.8.5 to 1.8.7, and then I can get the result.
              • L Offline
                @ken57093 but what code are you using?
                  @lastcaress
                  I'm using the example code from TinyGSM.h library.
                    ken57093
                    Hi
                    Now I'm trying the example code of GSM.h to set up a web server.
                    https://www.arduino.cc/en/Tutorial/GSMExamplesWebServer
                    It output a lot of error
                    Anyone knows what happened? thank you
