    How to switch the Atom Socket(HLW8023) on/off?
    4 Posts 2 Posters 4.6k Views
      tgprivate
      I can't get any description about the HLW8032 Socket's controll ways. Could anybody who has the python code to do this give me some tips? Thanks a lot.
      • felmueF Online
        Hello @tgprivate
        from the schematic the relay is switched on/off through GPIO23.
        Using UiFlow Pin blocks and looking at the Python code I get this:
        from m5stack import *
        from m5ui import *
        from uiflow import *
        import machine
        pin0 = machine.Pin(23, mode=machine.Pin.OUT, pull=machine.Pin.PULL_UP)
        pin0.on()
        pin0.off()
        Note: untested
          tgprivate @felmue
          @felmue It works according to your method, thank you very much!
          • felmueF Online
            Hello @tgprivate
            glad to hear it worked. And thank you for reporting back.
