    ATOM TF-CARD Kit SPI pins are not default SPI pins?
    Atom
    8.1k
      mviewlab
      I just wanted to ask if the pins used for SD card interface on ATOM TF-CARD Kit are just GPIO pins and they not default SPI pins of ESP32 Pico?
      Because I tried to use it with esp-idf and it does not work. Because SD card driver of esp-idf uses default SPI pins.
      Can you please suggest any way to use ATOM TF-CARD Kit with esp-idf?
        Hello @mviewlab
        yes, they are just GPIO pins. Please checkout the pinmap here.
        • P
          pieter
          How to use the ATOM TF-Card in Python?
          I tried to mount the TF-CARD as below with my ATOM Matrix but it when I load my code I get a red cross on the display. (I use cs=21 because it is not used in the ATOM)
          import uos
          uos.sdconfig(uos.SDMODE_SPI,clk=23,mosi=19,miso=33,cs =21)
          uos.mountsd()
            Hello @pieter
            this works for me:
            from machine import SDCard
            from machine import Pin
            import os
            try:
                sd = SDCard(slot=3, miso=Pin(33), mosi=Pin(19), sck=Pin(23), cs=Pin(4))
                sd.info()
                os.mount(sd, '/sd')
                print("SD card mounted at \"/sd\"")
            except (KeyboardInterrupt, Exception) as e:
                print('SD mount caught exception {} {}'.format(type(e).__name__, e))
                pass
            print(os.listdir('/sd'))
            Note: mostly taken from boot.py from an M5Core2 with modified pin config. CS pin is not really required as the SD card always selected anyways.
            • P
              pieter @felmue
              @felmue said in ATOM TF-CARD Kit SPI pins are not default SPI pins?:
              sd.info()
              Hi Felix,
              Thanks a lot.
              Your solution also works for me.
