    UIFlow 1.9.0
    Official Updates
    7
    14
    19.6k
    • m5stackM
      v1.9.0
      new features:
      • EN
        • UNIT ENCODER support.
        • SMART CONFIG support.
        • Fixed some bugs.
      new theme:
      ArnoA 1 Reply Last reply Reply Quote 1
        Hello @m5stack
        thank you for the new version of UIFlow.
        One thing that always strikes me as inconsistent is the fact that the button to load a program onto an M5Stack device is labelled Download whereas the information while it is happening (at the top right) says Upload.
        • ArnoA
          Arno @m5stack
          @m5stack Can you let us know when uiflow will be available for the ATOM Display? I bought this module several months ago and look forward to using an external LCD with Uiflow and the ATOM Display.
          • J
            jeczmienny
            Hello @m5stack
            the new version contains many new features as compared to 1.7.5 (offline).
            When can we expect the new OFFLINE version? There are still places and situations where you can not work online.
            Jacek
            • F
              Felix22
              Hello
              I have see, there is a new Version 1.9.1. What are the news ?
              Question for 1.9.0: What is
              • Unit Encoder and
              • Smart Config ?
              Thanks for your excellent work.
                Hello @m5stack
                the default GPIOs for the GPS module are incorrect when using M5Core2. They should be GPIO14 and GPIO13 (instead of GPIO17 and GPIO 16).
                  @IAMLIUBO im getting memory allocation errors when using 1.9.1 with azure. It looks to be that azure is filling the memory requiring the Core2 to be reset in order to update UIFlow program.
                  • IAMLIUBOI
                    IAMLIUBO @felmue
                    Now the button move to the bottom right,one is call "Run" means the workspace's code only run once,if you reboot the device code won't run again,and another one call "Download" means downlaod the workspace's code to the device filesystem and run, the code in the deivce won't disappear when you reboot or somethings.
                    In a word, "Run" button is recommend for developing mode, and "Download" button is deploy after develop.
                    • IAMLIUBOI
                      IAMLIUBO @Arno
                      @arno
                      UIFlow 2.0 will support this, sorry for wait us upgrade the UIFlow firmware until that.
                      • IAMLIUBOI
                        IAMLIUBO
                        @jeczmienny
                        Sorry for that, the offline version haven't update for a while, there are some reasons why we temporarily stop updating, we will fix it as soon as possible. Sorry again.
                        • IAMLIUBOI
                          IAMLIUBO @Felix22
                          @felix22
                          Hi, more info you can get in the below links:
                          Unit encoder
                          smarconfig
                          • IAMLIUBOI
                            IAMLIUBO @felmue
                            Thanks, we will fix this mistake.
                              felmue @IAMLIUBO
                              @iamliubo said in UIFlow 1.9.0:
                              Hello @IAMLIUBO
                              understood, but that was not my point. I am only talking about the "Download" button which when pressed shows a popup saying "Uploading".
                              but it's really just a cosmetic issue - don't worry about it.
                              • IAMLIUBOI
                                IAMLIUBO @ajb2k3
