    UiFLOW. I2C Programing
    8 Posts 5 Posters 12.8k Views 1 Watching
      timtimw
      Hello, any helpful info on working with I2C ? Trying to interface an ADC1115 to core2 and
      not clear on start stop, acknowledge bits.. Working from T.I. datasheet. Tying to write
      directly to address pointer, configuration register, with I2C read/write data instruction. Thanks for any help
      • felmueF Online
        Hello @timtimw
        the I2C functions in UIFlow will take care of start, stop and ack bits for you. Have you tried to use the I2C functions provided under Hardwares - I2C?
        I suggest you start with an I2C scan to see if the ADC1115 is found and the wiring is correct.
          ajb2k3 @timtimw
          @timtimw said in UiFLOW. I2C Programing:
          As Felmue has said, the start/stop/ACK are all handled behind the scenes all you need to do is use the blocks to read or write to the registers and decipher the data sent.
            timtimw
            Yup thanks,
            Works like a charm now with I2C write and read direct to registers. Easy after some hit and miss
            with data encoding. R/W 'short' with 'big' decode/ encode was the magic.
            Thanks for the help
            ArnoA bschwahnB 2 Replies Last reply Reply Quote 1
            • ArnoA Offline
              Arno @timtimw
              @timtimw Can you provide a screenshot, I tried to connect other I2C modules without success.
              Thanks in advance for sharing
              • bschwahnB Offline
                bschwahn @timtimw
                @timtimw
                That is awesome that you were able to get I2C to work with the ADC1115. I would be very interested in your ADC project at many of us discovered the built-in ADC has a few challenges. Again as Arno added could you please post /share your code? I am trying to use DS18B20 with UIFlow but am having some difficulties.
                Thanks Brian
                What doesn't kill me makes me stronger.
                ArnoA 1 Reply Last reply Reply Quote 0
                • ArnoA Offline
                  Arno @bschwahn
                  @bschwahn ds18b20 very easy to use with https://github.com/stonatm/UiFlow-custom-blocks/tree/master/ds18b20
                  bschwahnB 1 Reply Last reply Reply Quote 0
                  • bschwahnB Offline
                    bschwahn @Arno
                    @arno
                    Thanks Arno for the push in the right direction. I was able to get this to work on my Core 2 EXCEPT using G21 or G22.
                    I will write up a tutorial on try to find a way to post/share.
                    Thanks again Arno!
