ATOM SPK SPEAKER KIT
Hello, some example of how to use SPK with the library: github
How do I configure the output to use the spk chip?
I have modified an example in the ide, but I don't know if it is correct.This example in theory plays an mp3 station
Thanks for the help
All the best
Francisco#include <Arduino.h>
#include <M5Atom.h>
#include <WiFi.h>
#include "AudioFileSourceICYStream.h"
#include "AudioFileSourceBuffer.h"
#include "AudioGeneratorMP3.h"
//#include "AudioOutputI2SNoDAC.h"
#include "AudioOutputI2S.h"// Enter your WiFi setup here:
#ifndef STASSID
#define STASSID "TESTWIFI"
#define STAPSK "TEST"
#endif// Digital I/O used
#define I2S_DOUT 25 // DIN connection
#define I2S_BCLK 22 // Bit clock
#define I2S_LRC 21 // Left Right Clockconst char* ssid = STASSID;
const char* password = STAPSK;// Randomly picked URL
const char* URL = "http://kvbstreams.dyndns.org:8000/wkvi-am";AudioGeneratorMP3* mp3;
AudioFileSourceICYStream* file;
AudioFileSourceBuffer* buff;
//AudioOutputI2SNoDAC* out;
AudioOutputI2S* out = NULL;
//AudioOutputI2S* outvoid setup()
M5.begin();Serial.begin(9600); delay(1000); Serial.println("Connecting to WiFi"); WiFi.disconnect(); WiFi.softAPdisconnect(true); WiFi.mode(WIFI_STA); WiFi.begin(ssid, password); // Try forever while (WiFi.status() != WL_CONNECTED) { Serial.println("...Connecting to WiFi"); delay(1000); } Serial.println("Connected"); audioLogger = &Serial; file = new AudioFileSourceICYStream(URL); file->RegisterMetadataCB(MDCallback, (void*)"ICY"); buff = new AudioFileSourceBuffer(file, 2048); buff->RegisterStatusCB(StatusCallback, (void*)"buffer"); //out = new AudioOutputI2SNoDAC(); out = new AudioOutputI2S(0, 1, 32); out->begin(); mp3 = new AudioGeneratorMP3(); mp3->RegisterStatusCB(StatusCallback, (void*)"mp3"); mp3->begin(buff, out);}
void loop()
static int lastms = 0;if (mp3->isRunning()) { if (millis() - lastms > 1000) { lastms = millis(); Serial.printf("Running for %d ms...\n", lastms); Serial.flush(); } if (!mp3->loop()) mp3->stop(); } else { Serial.printf("MP3 done\n"); delay(1000); }}
// Called when a metadata event occurs (i.e. an ID3 tag, an ICY block, etc.
void MDCallback(void* cbData, const char* type, bool isUnicode, const char* string)
const char* ptr = reinterpret_cast<const char*>(cbData);
(void)isUnicode; // Punt this ball for now
// Note that the type and string may be in PROGMEM, so copy them to RAM for printf
char s1[32], s2[64];
strncpy_P(s1, type, sizeof(s1));
s1[sizeof(s1) - 1] = 0;
strncpy_P(s2, string, sizeof(s2));
s2[sizeof(s2) - 1] = 0;
Serial.printf("METADATA(%s) '%s' = '%s'\n", ptr, s1, s2);
Serial.flush();
}// Called when there's a warning or error (like a buffer underflow or decode hiccup)
void StatusCallback(void* cbData, int code, const char* string)
// Note that the string may be in PROGMEM, so copy it to RAM for printf
char s1[64];
strncpy_P(s1, string, sizeof(s1));
Serial.printf("STATUS(%s) '%d' = '%s'\n", ptr, code, s1);
Serial.flush();
}Thanks for the help
All the best
Francisco
