    M5Stack fire gyro mpu6050
    PROJECTS
    9.1k
    • I
      ItHasU
      I just received my M5 Fire + m5bala this morning.
      The M5 fire device is great. I played with M5 library with success (from Arduino) and managed to get some Hello world and other stuff running.
      My problem is when I run the m5bala sample.
      I did managed to compile and upload the sample, but the code won't work.
      After some debugging, it appears that I can drive the motors correctly by setting manual commands.
      However, the MPU6050 seems to be not responding as expected since I always have zero values.
      Here is a piece of code I use to test the MPU. I tried different versions of MPU6050 library with no difference.
      Any help is welcome, thank you.
      Regards
      #include <M5Stack.h>
      #include <MPU6050_tockn.h>
      #include <Wire.h>
      MPU6050 mpu6050(Wire);
      void setup()
      // Power ON Stabilizing...
      delay(500);
      M5.setPowerBoostKeepOn(false);
      Wire.begin();
      Wire.setClock(400000UL);  // Set I2C frequency to 400kHz
      mpu6050.begin();
      mpu6050.calcGyroOffsets(false);
      //mpu6050.setGyroOffsets(-2.70, -1.08, 0.87);
      M5.Lcd.setTextFont(2);
      M5.Lcd.setTextColor(TFT_WHITE, TFT_BLACK);
      M5.Lcd.println("M5Stack Balance Mode start");
      void loop()
      mpu6050.update();
      M5.Lcd.clear();
      M5.Lcd.setCursor(0, 0);
      M5.Lcd.printf("X: %f", mpu6050.getAngleX());
      M5.Lcd.setCursor(0, 20);
      M5.Lcd.printf("Y: %f", mpu6050.getAngleY());
      M5.Lcd.setCursor(0, 40);
      M5.Lcd.printf("Z: %f", mpu6050.getAngleZ());
      delay(500);
      // M5 Loop
      M5.update();
        • I
          ItHasU
          Ok, it seems that the problem was due to my version of ESP32 tools.
          I updated my ESP32 framework and now the code is working fine.
          Also, I used PlatformIO in VSCode which make things simpler since it enables the M5STACK_FIRE flag during compilation.
