    UIFlow 1.8.9
    Official Updates
    8
    11
    19.5k
    • m5stackM
      v1.8.9
      new features:
      • ZH-CN:
        • MQTT PRINTER 支持
        • SMART CONFIG 支持
      • EN:
        • MQTT PRINTER support
        • SMART CONFIG support
      • ArnoA
        Arno
        ATOM Display and the C3 !
        • P
          plusulli
          after switching to German I can not use Uiflow
          After that I have to clear the browser cache so that Uiflow starts again
          with the English version
          what is Smart Config Support?
          due hope for a C3 support I have given up
          ajb2k3A m5stackM 2 Replies Last reply Reply Quote 1
            ajb2k3 @plusulli
            @plusulli The C3 is so new that the Core Micropython doesn't fully support it yet!
            • G
              gcem5stack
              Hi, Do you think to update the desktop version soon to match a little bit with functions available in the beta v1.8.9?
              FYI, also the web version is 1.4.5, far away from the current desktop version v1.7.4...
              Thx by advance for you quick repply ;-)
              • m5stackM
                m5stack @plusulli
                @plusulli thank you feedback. now it fixed.
                • m5stackM
                  m5stack @Arno
                  @arno Still need to wait for a while
                  ArnoA 1 Reply Last reply Reply Quote -1
                    Hello @m5stack
                    thank you for fixing the font issue on M5Core2, which occurred in the previous UIFlow version 1.8.8., while downloading a program into the M5Core2. I appreciate it.
                    • ArnoA
                      Arno @m5stack
                      @m5stack I bought the ATOM DISPLAY and the C3 for a while. I hope that the use with Uiflow will be operational quickly.
                      I am falling behind on my projects and this is not the first time that Uiflow has not been available with the product.
                      • G
                        Genio @m5stack
                        @m5stack
                        I'm using CoreInk and i want realize a menu with a selection indicator.
                        This is part of the sketch i'm using:
                        I think there's a bug in M5Line when redraw because this is what i get:
                        https://drive.google.com/file/d/1kE_-J3Zrc57fYtHJqEOPY6LEf_pZhMYL/view?usp=sharing
                        The problem occurs also if i call a complete refresh instead of partial.
                        M5Rect has the same problem, M5Circle works fine.
                        • O
                          otosan-maker
                          I have updated to this version my core2 with faces keyboard, and the led are bright at 100%. I have not been able to stop them.
