    ATOM Lite - broker status LED? (with two devices)
    SOFTWARE
    6.6k
    • C
      ckohrt
      Hi all!
      I would really appreciate your help. I am new to M5Stack devices and tried to program an IR/WLAN gateway. When I programmed with my first device, I didn't realize that the status LED is not working any more. It worked at the beginning - I am sure. Then, with the same program I tried it on teh second device where the LED turned on with the first plug in of USB cable.
      Now, also the second device LED is probably brokern.
      I tried the simple demos blink.ino etc but could not get the LEDs running.
      My program looks as follows:
      #include <M5Atom.h>
      #include <WiFi.h>
      #include <WiFiMulti.h>
      // External library: IRRemoteESP8266, https://github.com/crankyoldgit/IRremoteESP8266
      #include <IRrecv.h>
      #include <IRremoteESP8266.h>
      // HW: Pin assignments
      const byte PIN_BUTTON = 39; // M5Stack Atom Lite: internal button
      const byte PIN_LEDATOM = 27; // M5Stack Atom Lite: internel Neopixel LED
      const byte PIN_LEDSTRIP = 26; // M5SAtack Atom Lite: Grove connector GPIO pin (yellow cable) -> Neopixel LED strip
      const byte PIN_IRRECV = 32; // M5SAtack Atom Lite: Grove connector GPIO pin (white cable) -> IR Receiver
      // Type declarations
      enum State {OFF = 0, ON = 1, ECO = 2}; // Main system states
      typedef enum State t_State;
      // Switch to receive debug messages via serial monitor
      const bool DEBUG_ON = false;
      // Status LED: color definitions
      const uint8_t COLOR_OFF[3] = {255, 0, 0}; // System state: OFF
      const uint8_t COLOR_ON[3] = {0, 255, 0}; // System state: ON
      const uint8_t COLOR_ECO[3] = {0, 255, 0}; // System state: ECO
      // Status LED and LED strip: Brightness constants
      const uint8_t BRIGHTNESS_OFF = 8; // System state: OFF
      const uint8_t BRIGHTNESS_ON = 20; // System state: ON
      const uint8_t BRIGHTNESS_ECO = 10; // System state: ECO
      const uint8_t BRIGHTNESS_MIN = 2; // Lowest brightness
      const uint8_t BRIGHTNESS_MAX = 50; // Highest brightness --> maximum current
      const uint8_t BRIGHTNESS_STEP = 2; // Increment for brightness adjustement via IR remote
      // Time constant, i.e. time after which light effects are updated
      const int TIME_CYCLE = 5; // ms
      // IR Commands (values depend on the remote control used)
      const uint64_t IR_CHminus = 0xFFA25D;
      const uint64_t IR_CH = 0xFF629D;
      const uint64_t IR_CHplus = 0xFFE21D;
      const uint64_t IR_PREV = 0xFF22DD;
      const uint64_t IR_NEXT = 0xFF02FD;
      const uint64_t IR_PLAY = 0xFFC23D;
      const uint64_t IR_MINUS = 0xFFE01F;
      const uint64_t IR_PLUS = 0xFFA857;
      const uint64_t IR_EQ = 0xFF906F;
      const uint64_t IR_ZERO = 0xFF6897;
      const uint64_t IR_HUNDRET = 0xFF9867;
      const uint64_t IR_TWOHUNDRET = 0xFFB04F;
      const uint64_t IR_ONE = 0xFF30CF;
      const uint64_t IR_TWO = 0xFF18E7;
      const uint64_t IR_THREE = 0xFF7A85;
      const uint64_t IR_FOUR = 0xFF10EF;
      const uint64_t IR_FIVE = 0xFF38C7;
      const uint64_t IR_SIX = 0xFF5AA5;
      const uint64_t IR_SEVEN = 0xFF42BD;
      const uint64_t IR_EIGHT = 0xFF4AB5;
      const uint64_t IR_NINE = 0xFF52AD;
      // IR receiver library parameters
      const uint16_t IR_BUFFER_SIZE = 1024;
      const uint8_t IR_MSG_TIMEOUT = 15;
      // Homematic stuff
      String ISE_ID = "24561"; //testvar
      String ip = "192.168.66.64"; // Arduino IP-Adresse
      const char * HomematicIP = "192.168.66.65"; // Homematic IP-Adresse
      const uint16_t HomematicPort = 80; //The port of the TCP server is specified.
      // Object and variable definitions
      //EthernetClient client;
      WiFiMulti WiFiMulti;
      WiFiClient client;
      bool connected;
      //IR receive
      IRrecv IrRecv(PIN_IRRECV, IR_BUFFER_SIZE, IR_MSG_TIMEOUT, true);
      // Buffer for decoded IR command
      decode_results irCmd;
      // IR command status
      bool irCmdAvailable = false; // True, if new IR code has been received and decoded
      // Last IR command received and decoded
      uint64_t irCmdValue = 0;
      // Setup routine
      void setup()
      delay(1000);
      if (DEBUG_ON)
      Serial.begin(115200);
      Serial.print("\nWaiting connect to WiFi...");
      M5.begin(true, false, true); //Init Atom(Initialize serial port, LED).
      M5.dis.setBrightness(10); // tried to set this - also to 100. But was not there when I damaged the status LED.
      WiFiMulti.addAP("mywlan", "mypass"); //Add wifi configuration information.
      while (WiFiMulti.run() != WL_CONNECTED) { //If the connection to wifi is not established successfully.
      if (DEBUG_ON) Serial.print(".");
      delay(300);
      if (DEBUG_ON)
      Serial.println("\nWiFi connected");
      Serial.print("IP address: ");
      Serial.println(WiFi.localIP());
      // initialize the button object
      M5.update();
      IrRecv.enableIRIn(); // Switch on IR receiver after initialization
      M5.dis.drawpix(0, 0x00ff00); //GREEN
      // Main routine
      void SendHttp(String IRVal)
      M5.dis.drawpix(0, 0xfff000);
      if (client.connect(HomematicIP, HomematicPort)) {
      if (DEBUG_ON) Serial.println("connected");
      if (DEBUG_ON) Serial.println("Value: (dec)" + IRVal);
      client.println("GET /config/xmlapi/statechange.cgi?ise_id=24561&new_value=" + IRVal + " HTTP/1.0");
      client.println(); // end HTTP header
      /*while (client.available()) {
        char c = client.read();
        if (DEBUG_ON) Serial.print(c);
      client.stop();
      } else {
      if (DEBUG_ON) Serial.println("connection failed");
      M5.dis.drawpix(0, CRGB::Red); //RED
      delay(1000);
      M5.dis.drawpix(0, CRGB::Green); //GREEN
      void loop()
      bool irCmdOnOff = false;
      // Determine the IR command state
      irCmdAvailable = IrRecv.decode(&irCmd);
      if (irCmdAvailable)
      M5.dis.drawpix(0, CRGB::Blue); //BLUE
      if (irCmd.repeat) // Is it a repetition of the previous IR command?
      irCmdValue = 0x0;
      else {
      // No repetition: retrieve the IR command
      irCmdValue = irCmd.value;
      IrRecv.resume();
      if (irCmdAvailable)
        if (DEBUG_ON) Serial.print("IR: ");
        if (DEBUG_ON) Serial.println((unsigned long) irCmd.value, HEX);
        String IRValue = String((unsigned long)irCmd.value, HEX);
        SendHttp(IRValue);
      // Process events "button released" or "IR on/off" respectively
      if (M5.Btn.wasPressed() )
      M5.dis.drawpix(0, CRGB::White); //GREEN
      if (DEBUG_ON) Serial.println("Button pressed");
      delay(TIME_CYCLE); // Pause before next pass through loop
      I use the Arduino IDE and tried to get the IR Unit running. The functionality is there, so my gateway is working. But when I order new ATOM LITEs I'd like to know which failure I did....
      Thanx
      Christian
        Hello @ckohrt
        the LED in your M5Atoms are most likely not broken. Try this example.
        From that example it looks like a delay(50); is required before the first call to M5.dis.drawpix(); else the LED stays dark.
        • C
          ckohrt
          @felmue said in ATOM Lite - broker status LED? (with two devices):
          delay(50);
          Thanks, I'll try that...
          • C
            ckohrt
            Ok, I copied the program and uploaded it, the LED stays dark. :(
            I am using the M5Stack-ATOM Board, I don't know if I have to use another one. But I couldn't find the "M5Stack-ATOM LITE". Do I need this?
            The M5Atom library is up to date version 0.0.7.
            It seems that there is an issue on git....
            I tried to downgrade to M5Atom Version 0.0.5 - didn't work. I also downgraded FastLED to 3.3.3 (from 3.4.0) with current M5Atom version 0.0.7- YES IT DID WORK!!!!!
            Thank you VERY MUCH @felmue for your hint which led me to the right direction!
            • P
              paulhdietz
              @ckohrt - I also posted about this issue last week: https://community.m5stack.com/topic/3812/atom-lite-led
              I had to downgrade the installed M5Stack-ATOM board to pre 2.0.0 to get it to work.
