    M5stack Fire - no check code for binding device
    FAQS
    5
    10
    15.0k
    • C
      Calypticus
      Hi all!
      I hope this question is not too simple. I finally got my new m5stack fire, unboxed it, connected first to the m5-wifi then entered my SSID and let the device reboot. The next step would be to bind the m5stack to my io.m5stack with the check code. BUT: where is this code? The m5stack just shows either a rock paper scissor button test or a screen with some lessons and the information, that no device has been connected yet. No code anywhere to be seen. I am sure, I am just missing something very simple but anyhow - its a blocking point that prevents me from the acutal coding. ;-)
      Thanks for your support.
      Caly.
        soogie @Calypticus
        @calypticus Hi, I just have bumped into the same problem as you.
        m5-docsM 2 Replies Last reply Reply Quote 0
          mynameisdavehi
          @soogie me three :(
          • m5-docsM
            m5-docs
            • m5-docsM
              m5-docs @soogie
              • m5-docsM
                m5-docs @soogie
                @soogie Hello
                Try to burn a M5GO firmware please.
                This is the article about how to burn a firmware
                https://m5stack.readthedocs.io/en/latest/get-started/how_to_burn_firmware_en.html
                • m5-docsM
                  m5-docs @mynameisdavehi
                  @mynameisdavehi Hello
                    soogie @m5-docs
                    @watson Thank you, but I use mac.
                    I will look for some way to burn ith my mac.
                    • lukasmaximusL
                      Hi @soogie there is information on burning the firmware for mac operating system in the link that @watson sent. Alternatively we also made a youtube video showing you how to burn the firmware on Mac here
                        soogie
                        @lukasmaximus Thank you for your comment. I'll see Youtube later.
