    ATOM RS-485 - No power via USB
    2 Posts 2 Posters 4.0k Views
    • W Offline
      watchforstock
      I've been using the ATOM RS-485n kit (https://docs.m5stack.com/en/atom/atomic485) to connect to an electricity meter using ESPHome. Last night this was working with the A/B wires connected to the meter and the ATOM lite powered via the USB connection to my laptop.
      Today, for some reason, if I plug the ATOM lite into the RS485 unit then it won't power at all via USB whether or not the A/B wires are connected. I must be doing something different, but for the life of me can't work out what is different.
      Should I expect to be able to power it by USB? Is there something I might have done (software or hardware) that would stop that happening. The ATOM lite is still working - if I connect it without the RS-485 base then it works exactly as expected.
      Any suggestions very welcome!
      Andrew
        Hello @watchforstock
        looking at the ATOM RS485 schematic the only way I see which would keep the M5Atom from powering up when plugged into the ATOM RS485 is if somehow the 5 V line is (partly) shorted to GND.
        Now, there is a built-in DC-DC converter in the ATOM RS485 converting the input voltage from the RS485 connector to 5 V. In your case however this DC-DC converter is not fed an input voltage. Maybe the DC-DC converter IC didn't like the fact it was fed 5 V into its output from the M5Atom.
        You could try to measure the 5 V on the Groove connector while the M5Atom is plugged into the ATOM RS485 to see if it somehow is pulled down.
