    Where is LAN Module example??
    lan module
    10 Posts 4 Posters 28.0k Views 1 Watching
    • N Offline
      nnn
      I would like to try "LAN Module with W5500 Chip".
        sheepDog
        I am looking also for the example.
          sheepDog
          can anyone help with a working LAN Module example for W5500?
            sheepDog
            Hello M5Stack-Admin,
            the link for the LAN-Modul at your homepage is corrupt.
            This part didn't work:
            Documents
            Example
            Arduino Example
            Please look at "Documents" at this page: https://github.com/m5stack/m5stack-documentation/blob/master/en/product-documents/modules/m5stack_lan_module.rst
            • N Offline
              nnn @sheepDog
              I found an example of W5500, but it did not work.
              W5500 example is
              https://github.com/adafruit/Ethernet2
              But,I get the following error in my environment.
              Failed to configure Ethernet using DHCP
              My code is
              #include <SPI.h>
              #include <Ethernet2.h>
              byte mac[] = {
                0x00, 0xAA, 0xBB, 0xCC, 0xDE, 0x02 };
                Serial.begin(115200);
                if (Ethernet.begin(mac) == 0) {
                  Serial.println("Failed to configure Ethernet using DHCP");
                  // no point in carrying on, so do nothing forevermore:
                  for(;;)
                Serial.print("My IP address: ");
                for (byte thisByte = 0; thisByte < 4; thisByte++) {
                  Serial.print(Ethernet.localIP()[thisByte], DEC);
                  Serial.print(".");
                Serial.println();
              • N Offline
                nnn @nnn
                And, Arduino Example page in M5Stack LAN Module is "Page not found".
                M5Stack-Admin,I want you to correspond.
                • N Offline
                  nnn
                  My problem was solved below.
                  https://github.com/m5stack/M5Stack/tree/master/examples/Modules/W5500
                  https://github.com/m5stack/m5stack-documentation/issues/4
                  • m5-docsM Offline
                    m5-docs
                    Here is the LAN example
                    I have updated at the m5stack document website
                    please visit https://m5stack.readthedocs.io/en/latest/product-documents/modules/m5stack_lan_module.html
                    M5Stack documentation URL
                    https://docs.m5stack.com
                    • m5-docsM Offline
                      m5-docs @nnn
                      @nnn Thank you!
                        Matthew
                        Hi!
                        Here is an example (Korean but you can using code, Simple Chat Server)
                        https://www.wiznetian.com/m5stack-lan-λͺ¨λ“ˆμ„-μ΄μš©ν•œ-κ°„λ‹¨ν•œ-μ±„νŒ…-μ„œλ²„-λ§Œλ“€κΈ°/
                        And I will publish this document in English as soon as possible. :D
                        With your input, this post could be even better πŸ’—
