Serial2 Don't compile
I have recently changed to using https://dl.espressif.com/dl/package_esp32_index.json in the boards manager now any application using serial2 wont comple. I get an error Error compiling for board M5Stack-Core-ESP32.
David Ardis
@ardisd Can you post a screenshot of the error ouput from arduino?
Enclosed screen shot as requested
I get the same error when compiling Serial2.ino and my own code
Are you running arduino 1.8.7?
Thats not all the error. -
Upgraded to 1.8.7 was on 1.8.5
This is the error now
I first thought is to tell you to Backup and delete the SD folders in dropbox and
C:\programfiles(x86)\Arduino\Librarys\SD
and then try again.Can I see your source code?
Just the standard serial2 sketch
#include <M5Stack.h>
HardwareSerial Serial2(2);
Serial.begin(115200);
// Serial2.begin(unsigned long baud, uint32_t config, int8_t rxPin, int8_t txPin, bool invert)
Serial2.begin(115200, SERIAL_8N1, 16, 17);
}void loop() {
if(Serial.available()) {
int ch = Serial.read();
Serial2.write(ch);
}if(Serial2.available()) {
int ch = Serial2.read();
Serial.write(ch);
I got the same problem.
I changed the rename of Serial2 and fixed it.HardwareSerial Serial2(2);
→HardwareSerial Serial2_(2); -
