    M5stack cam no picture
    PRODUCTS
    15.1k
    • C
      corto
      i bought a M5Stack Official ESP32 WROVER with PSRAM Camera Module OV2640 Type-C Grove Port Mini Camera Development Board Building Brick.
      It was always rebooting
      Rebooting...
      ets Jun 8 2016 00:22:57
      rst:0xc (SW_CPU_RESET),boot:0x33 (SPI_FAST_FLASH_BOOT)
      configsip: 0, SPIWP:0xee
      Rebooting...
      i load : Github.com/m5stack/esp32-cam-demo/tree/m5cam-psram
      result:
      wifi ok
      but no image just a black screen with a small white square in the center
      i load : m5cam-firmware.zip
      result:
      wifi ok
      but the red led is off
      i read on com :
      I (569) camera_demo: Camera demo ready
      I (19499) camera_demo: station:44:78:3e:5f:ec:2e join, AID=1
      dhcps: send_offer>>udp_sendto result 0
      I (20269) tcpip_adapter: softAP assign IP to station,IP is: 192.168.4.2
      W (26249) http_server: Expected response size: 18400, actual: 0
      what is wrong?
        ajb2k3 @corto
        @corto did you get a file downloading from the camera?
        • C
          corto
          Yes i have
          • C
            corto
            Yes i have
              Thats the default demo firmware. it should have created a file.
              Look at you wifi connections, do you see M5cam in the wifi manager?
              Mine doesn't show anything on the screen but does capture images.
              Also, they do overheat badly.
              • C
                corto
                Yes i see m5stack wifi 192.168.4.1 and the connexion is ok
                  http://192.168.4.1 is the address.
                  http://192.168.4.1:80 is the only open port.
                  http://192.168.4.1/pgm grayscale image.
                  http://192.168.4.1/bmp_stream - BMP stream.
                  http://192.168.4.1/jpg_stream - jpg stream.
                  But again, you may not see anything on the screen.
                  • C
                    corto
                    idem no picture
                      Look in your "downloads folder" (where ever you download files to)
                      You should see a strange file. When you open the file, there will be captured images in it.
                      I'm waiting on my MK2 camera (WROVER) to arrive to see what the difference in the 2 are.
                      • C
                        corto
