    Warranty question M5stack is dead
    PRODUCTS
    15
    27.8k
    • I
      ispybadguys
      I was wondering what the Warranty is for the M5sstack. I have purchased may accessories and the the Fire module but the original unit I bought on Amazon from Maker Focus in late January just quit powering up. It is simply bricked. I was working fine a few days ago.
        Does it appear on a computer when you plug it in?
        Have you tried uploading a program without connecting a battery?
        Have you tried another usb to uart adapter to connect to the M5?
        • I
          ispybadguys
          It doesn’t appear on the computer. It doesn’t power up with 2 different cables and 2 different USB supplies or when plugged in to the computer USB or on the internal battery.
          • I
            ispybadguys
            I plugged the M5Stack into a USB power source and measured the power pins with a DVM. The Battery pin measures 4.2V, the 3.3 volt pin measures 3.3 volts, and the 5V pin 5 volts. But the device does not power up.
            • I
              ispybadguys
              I tried some additional troubleshooting. I removed the bottom battery slice and plugged the top slice into my computer. There is no connection to the device so nothing can be uploaded. The display is also dark in this configuration and with it plugged into a USB charger.
              • I
                ispybadguys
                I seems that the problem resolved itself. This is very strange. I removed the battery slice several times but this did not resolve the problem. I even removed it once for at least a day. Finally I removed that battery slice and I let the unit sit for several days without the battery. When I reconnected the battery it started working link nothing ever happened.
                • m5-docsM
                  m5-docs @ispybadguys
                  @ispybadguys A Power supply problem, please contact to Hardware Engineer of M5Stack
                  tech@m5stack.com
                  M5Stack documentation URL
                  https://docs.m5stack.com
                  • KabronK
                    Kabron
                    I also have a question. I got M5Fire in M5Bala set.
                    Half of USB-C does not work, i.e.: in one position PC does discover device, while in 180 degrees opposite - does not.
                    Is it a kind of warranty case?
                    I wrote to official M5Store seller on aliexpress, but got no answer.
                      ajb2k3 @Kabron
                      @kabron get a new lead, I get this with an expensive leads.
                      • KabronK
                        Kabron @ajb2k3
                        @ajb2k3 在 Warranty question M5stack is dead 中说:
                        You mean to try another cable? I tried all I have.
                          ajb2k3 @Kabron
                          @kabron I brought 4 different ones before I found one that works in any direction.
                          I ended up paying £20 for a lead and that only works if the usb C connector is in a certain rotation.
                          Yes I brought 4 leads spending over £30 just on leads!
                          • m5-docsM
                            m5-docs @Kabron
                            Hi, kabron @kabron Does your Type-C cables work now?
                            • KabronK
                              Kabron @m5-docs
                              @watson 在 Warranty question M5stack is dead 中说:
                              It works in only one direction(position).
                              • m5-docsM
                                m5-docs @Kabron
                                @kabron
                                Hi
                                You means that only one direction(positive) which USB-C cables inserted to PC, and PC will discover usable Serial Port.
                                If you turn USB-C cable around 180 degrees, the serial port will disappear.
                                Do I descripte your phenomenon correctly?
                                • KabronK
                                  Kabron @m5-docs
                                  Absolutelly correct.
                                  I have to mark socket sides of all my cables
