"get Battery Level" issue
Hi, I am using the 24bit HX711 connected on port A to measure the weight from sensor. All works, but when call the "get Battery level" , the measurement show nonsense number and stop working. Any idea ?
Device: M5Stack core
firmware: v1.8.3 (via M5Burner)
UIFlow: v1.8.3 -
Hi @rbarsa ,
Could you paste your block code picture? -
from m5stack import *
from m5ui import *
from uiflow import *
import unitsetScreenColor(0x222222)
weigh_1 = unit.get(unit.WEIGHT, unit.PORTA)proc = M5TextBox(90, 46, "proc", lcd.FONT_DejaVu40, 0xFFFFFF, rotate=0)
gram = M5TextBox(128, 125, "gram", lcd.FONT_DejaVu40, 0xFFFFFF, rotate=0)
label2 = M5TextBox(0, 46, "Bat:", lcd.FONT_DejaVu40, 0xFFFFFF, rotate=0)
label3 = M5TextBox(0, 125, "Wght:", lcd.FONT_DejaVu40, 0xFFFFFF, rotate=0)weigh_1.zero()
while True:
gram.setText(str(weigh_1.weight))
proc.setText(str(power.getBatteryLevel()))
wait_ms(2) -
When using the MQTT the simmilar problem occure. The weight value sometimes shows nonsense number.
