    Change I2C address of joystick module
    SOFTWARE
    joystick i2c
    5.6k
    • T
      tttttttom
      hi,
      does anyone know if it is possible to change the i2c address of a joystick module? I would like to use two joysticks on the port A.
      I am very geartful for any hint..
      thanks and regards
      tom
        Hello @tttttttom
        if I am not mistaken there is no joystick module - did you mean the joystick unit?
        The joystick unit uses an MEGA328P processor inside which most likely has the I2C address programmed in it and I cannot find the source of the firmware running inside the MEGA328. Given that I would say you cannot change the I2C address.
        Your best bet would be a PaHub unit which has been developed exactly to solve that use case.
        • T
          tttttttom
          Hello Felix,
          thank you for sharing your knowledge. And yes, my question concerns the joystick UNIT. And yes, I would like to change the i2c address inside the MEGA328P. But the unit you are mentioning is also fine. I will check that ...
          Regards
          Tom
            @felmue is correct here that the PaHub is what needed however,
            There is a header inside that if you solder the pins, the address will change.0_1630333824840_address.png
              Hello guys
              @ajb2k3 : that is interesting - thanks for sharing.
              @tttttttom : sorry for misleading you.
              Also interestingly these address pins are not mentioned in the schematic.
                ajb2k3 @felmue
                @felmue they are, its just that it takes a bit of comparison work to spot them.
                they appear as R17, R18 and R19.
