    UIFlow 1.8.1
    Official Updates
    11
    21
    61.4k
    • m5stackM
      Ver 1.8.1 time: 2021.07.23
      v1.8.1
      Bug fix:
      • UNIT
        • UHF RFID read data bug fix.
      • LoRaWAN:
        • Downlink data will loss bug fix.
      • COM.X
        • COM.LTE http_get func bug fix.
      • Others bug fix.
      • P
        plusulli
        the Slider problem with Remore+ is still not fixed in three country versions still the same error that no data is transferred
        addendum the error also occurred with the switch and the input function
        ok
        not ok
        • saitotetsuyaS
          saitotetsuya
          There is a typo in the "Power on" block for MyCobot and MyCobot Pro.
          alt text
          • OyczEO
            OyczE
            Lorawan868 - element got a wrong python lib link
            Its should be 868 not 915
            gif
            @m5stack when this will be fixed ? or again there is no issue ?
            • P
              plusulli
              the Dual-BUTTON Unit no longer works in this UIflow version.
              • m5stackM
                m5stack @plusulli
                @plusulli thank you feedback. it already fixed.
                • P
                  plusulli @m5stack
                  @m5stack said in UIFlow 1.8.1:
                  Great that's how it has to be
                    Hello @m5stack
                    on M5Core2 (running UIFlow fw 1.8.1), with the boot menu option set to false, still shows the splash screen and the menu screen before actually starting the previously downloaded .py code.
                    Could you please have a look?
                    P.S. Reported here.
                    • m5stackM
                      m5stack @felmue
                      @felmue you could change the mode option to the WiFi mode in the boot menu. and then reboot the device it will starting the UIFlow program mode.
                      • F
                        favnec5 @m5stack
                        @m5stack
                        Hello. Sorry but i don't understand. Wifi mode will display wifi ssid for wifi connection. The problem is that, in the app mode, "boot menu : false" in the M5Burner software don't hide the splash screen and the boot menu at core2 startup.
                        Thanks.
                        Thomas
                        Thomas
                          Hello @m5stack
                          I am sorry, but there is no WiFi mode for M5Core2 - or am I missing something?
                          I only see Internet Mode, USB Mode and App Mode.
                          • m5stackM
                            m5stack @felmue
                            @felmue actually the WIFI mode is the Internet Mode. they are same
                              Hello @m5stack
                              thank you for the clarification. However when I use Internet Mode my M5Core2 shows the UIFlow flash screen, the UIFlow menu and then connects to the UIFlow Cloud. (Which btw is what I would expect it to do in Internet Mode.)
                              As stated before, also by favnec5, is that with Start Mode set to App Mode and Boot Menu set to False M5Core2 still shows the UIFlow flash screen and the UIFlow menu before starting the previously downloaded .py code.
                              Please fix or advise.
                              P.S. the issue only is with M5Core2 - it works properly on M5Stack devices.
                                Still no way to read and write to SD cards in UIFLow on the M5Paper?
                                • R
                                  retro
                                  Hi! When will the UIFlow Desktop be updated to version 1.8.1?
                                  • NN708N
                                    NN708
                                    Hello @m5stack,
                                    I want to modify the MicroPython code for PaHUB, but I found that the repository on GitHub (https://github.com/m5stack/UIFlow-Code) is outdated. Could you update this repository to the newest version?
                                      Can't connect NCIR to PaHub in UIFlow
                                      • IAMLIUBOI
                                        IAMLIUBO @ajb2k3
                                        @ajb2k3 said in UIFlow 1.8.1:
                                        Thanks feedback, we will update this issue.
                                        • T
                                          tnkmasayuki
                                          UIFlow1.8.1
                                          The MAC address of EspNow is the MAC address of SoftAP.
                                          The Mac address of EspNow reception is the MAC address of Station mode.
                                          They are different numbers and should be unified to Station mode.
                                            ajb2k3 @tnkmasayuki
                                            @tnkmasayuki AP and Station need different mac address in order to communicate in different modes.
