    [SOLVED] ATOM LITE + OLED Unit 1.3" 128 × 64 Display
    Atom
    25.4k
    • m5stackM
      just use the M5GFX library.
      https://github.com/m5stack/M5GFX
      • C
        cepics
        the library examples doesn't work for me
        I tryed with core gray, core2, atom lite without any result...
        may be I'm missing something......
        • C
          cepics
          some tips???
          • O
            otosan-maker
            why is it not working? Any error code? it is difficult to help you if you give no information.
            • C
              cepics
              I can upload the exemples sketches but nothing is on the display....
              • C
                cepics
                • arduino envirement
                • atom lite
                • oled unit
                • up to date M5GFX
                this is a test sketch:
                #include <M5GFX.h>
                M5GFX display;
                M5Canvas canvas(&display);
                static constexpr char text0[] = "hello world";
                static constexpr char text1[] = "this";
                static constexpr char text2[] = "is";
                static constexpr char text3[] = "text";
                static constexpr char text4[] = "log";
                static constexpr char text5[] = "vertical";
                static constexpr char text6[] = "scroll";
                static constexpr char text7[] = "sample";
                static constexpr const char* text[] = { text0, text1, text2, text3, text4, text5, text6, text7 };
                void setup(void)
                  display.begin();
                  if (display.isEPD())
                    display.setEpdMode(epd_mode_t::epd_fastest);
                    display.invertDisplay(true);
                    display.clear(TFT_BLACK);
                  if (display.width() < display.height())
                    display.setRotation(display.getRotation() ^ 1);
                  canvas.setColorDepth(1); // mono color
                  canvas.createSprite(display.width(), display.height());
                  canvas.setTextSize((float)canvas.width() / 160);
                  canvas.setTextScroll(true);
                void loop(void)
                  static int count = 0;
                  canvas.printf("%04d:%s\r\n", count, text[count & 7]);
                  canvas.pushSprite(0, 0);
                  ++count;
                this is the arduino ide output:
                Lo sketch usa 301153 byte (22%) dello spazio disponibile per i programmi. Il massimo è 1310720 byte.
                Le variabili globali usano 17052 byte (5%) di memoria dinamica, lasciando altri 310628 byte liberi per le variabili locali. Il massimo è 327680 byte.
                esptool.py v3.0-dev
                Serial port COM8
                Connecting.....
                Features: WiFi, BT, Dual Core, 240MHz, Embedded Flash, VRef calibration in efuse, Coding Scheme None
                Crystal is 40MHz
                MAC: d8:a0:1d:5c:95:0c
                Uploading stub...
                Running stub...
                Stub running...
                Changing baud rate to 1500000
                Changed.
                Configuring flash size...
                Auto-detected Flash size: 4MB
                Compressed 8192 bytes to 47...
                Writing at 0x0000e000... (100 %)
                Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.0 seconds (effective 4096.1 kbit/s)...
                Hash of data verified.
                Compressed 15856 bytes to 10276...
                Writing at 0x00001000... (100 %)
                Wrote 15856 bytes (10276 compressed) at 0x00001000 in 0.1 seconds (effective 991.0 kbit/s)...
                Compressed 301264 bytes to 153424...
                Writing at 0x00010000... (10 %)
                Writing at 0x00014000... (20 %)
                Writing at 0x00018000... (30 %)
                Writing at 0x0001c000... (40 %)
                Writing at 0x00020000... (50 %)
                Writing at 0x00024000... (60 %)
                Writing at 0x00028000... (70 %)
                Writing at 0x0002c000... (80 %)
                Writing at 0x00030000... (90 %)
                Writing at 0x00034000... (100 %)
                Wrote 301264 bytes (153424 compressed) at 0x00010000 in 2.8 seconds (effective 870.7 kbit/s)...
                Compressed 3072 bytes to 128...
                Wrote 3072 bytes (128 compressed) at 0x00008000 in 0.0 seconds (effective 1365.3 kbit/s)...
                Leaving...
                Hard resetting via RTS pin...
                Trovata libreria non valida in C:\Users\Documents\Arduino\libraries\M5Stack_LovyanLauncher-master: Nessun header file (.h) trovato in C:\Users\Documents\Arduino\libraries\M5Stack_LovyanLauncher-master
                Trovata libreria non valida in C:\Users\Documents\Arduino\libraries\URM-master: Nessun header file (.h) trovato in C:\Users\Documents\Arduino\libraries\URM-master
                this is the serial monitor booting the atom lite
                ets Jun  8 2016 00:22:57
                rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
                configsip: 188777542, SPIWP:0xee
                mode:DIO, clock div:1
                load:0x3fff0018,len:4
                load:0x3fff001c,len:1044
                load:0x40078000,len:8896
                load:0x40080400,len:5816
                entry 0x400806ac
                • C
                  cepics
                  I think I have to change the i2c pin in the library..... but where??
                  • m5stackM
                    you need to #include <M5UnitOLED.h>
                    M5UnitOLED display;
                    static constexpr char text[] = "Hello world ! こんにちは世界! this is long long string sample. 寿限無、寿限無、五劫の擦り切れ、海砂利水魚の、水行末・雲来末・風来末、喰う寝る処に住む処、藪ら柑子の藪柑子、パイポ・パイポ・パイポのシューリンガン、シューリンガンのグーリンダイ、グーリンダイのポンポコピーのポンポコナの、長久命の長助";
                    static constexpr size_t textlen = sizeof(text) / sizeof(text[0]);
                    int textpos = 0;
                    int scrollstep = 2;
                    void setup(void)
                      display.init();
                      display.setRotation(2);
                      canvas.setFont(&fonts::lgfxJapanMinchoP_32);
                      canvas.setTextWrap(false);
                      canvas.setTextSize(2);
                      canvas.createSprite(display.width() + 64, 72);
                    void loop(void)
                      int32_t cursor_x = canvas.getCursorX() - scrollstep;
                      if (cursor_x <= 0)
                        textpos = 0;
                        cursor_x = display.width();
                      canvas.setCursor(cursor_x, 0);
                      canvas.scroll(-scrollstep, 0);
                      while (textpos < textlen && cursor_x <= display.width())
                        canvas.print(text[textpos++]);
                        cursor_x = canvas.getCursorX();
                      display.waitDisplay();
                      canvas.pushSprite(&display, 0, (display.height() - canvas.height()) >> 1);
                    C 1 Reply Last reply Reply Quote 1
                    • C
                      cepics @m5stack
                      @m5stack said in ATOM LITE + OLED Unit 1.3" 128 × 64 Display:
                      M5UnitOLED display;
                      int textpos = 0;
                      int scrollstep = 2;
                      void setup(void)
                        display.init();
                      void loop(void)
                        if (cursor_x <= 0)
                          textpos = 0;
                      this sketch compile but doesn't display nothing
                      no error message
                      this is the atom lite boot on serial monitor after uploaded sketch
                      entry 0x400806ac
                      • O
                        otosan-maker @cepics
                        @cepics said in ATOM LITE + OLED Unit 1.3" 128 × 64 Display:
                        I don´t like it ... please remove it and give a try in the loop with a static string ...
                        And also, put any serial.println() debug code to see what code are you running
                        • C
                          cepics
                          @otosan-maker said in ATOM LITE + OLED Unit 1.3" 128 × 64 Display:
                          ...and give a try in the loop with a static string ...
                          sorry but I don't understand ...
                          I deleted :
                          this is the compiling error message
                              Arduino:1.8.13 (Windows 10), Scheda:"M5Stick-C, Default, 1500000, None
                              C:\Users\Documents\Arduino\OLEDDAJE\OLEDDAJE.ino: In function 'void loop()':
                              OLEDDAJE:41:39: error: 'text' was not declared in this scope
                              Più di una libreria trovata per "SPI.h"
                              Usata: C:\Users\AppData\Local\Arduino15\packages\m5stack\hardware\esp32\1.0.7\libraries\SPI
                              Non usata: C:\Users\Documents\Arduino\libraries\SPI
                              exit status 1
                              Questo report potrebbe essere più ricco di informazioni abilitando l'opzione
                              "Mostra un output dettagliato durante la compilazione"
                              in "File -> Impostazioni
                          • m5stackM
                            //M5UnitOLED display; // default setting
                            M5UnitOLED display ( 21, 22, 400000 ); // SDA, SCL, FREQ
                            • C
                              cepics
                              tnks a lot !!!!
                              this sketch is working for me
                              M5UnitOLED display ( 26, 32, 400000 ); // SDA, SCL, FREQ
                              int textpos = 0;
                              int scrollstep = 2;
                              void setup(void)
                                display.begin();
                              void loop(void)
                                if (cursor_x <= 0)
                                  textpos = 0;
