    EspNow is receiving previous messages
    uiflow
    3 Posts 3 Posters 7.2k Views 1 Watching
      SlashAndBurn
      I've started work on a project to make a sports tracker and it was working well for a bit, but now i'm a little confused on how the EspNow is working.
      Esp Setup on Controller
      Esp Setup on Check-In Points
      My Setup
      Core2 as the Brains
      Atom X 2 as the check in points
      When the player taps the RFID card against the reader at either check in point it send the device's MAC Address + "@" + "PYLON" + "@" + Players name to the hub device. Then the hub will receive the message and process it later. After it has been processed the hub send a signal to the check-in point to display a "!" symbol.
      The odd thing is, if I restart every piece and start scanning, the wrong check-in point will get the signal. Then if I scan it again, it moves to the right point, but if I move to the next point, the last check-in point receives the signal. So it is acting like a buffer and the last one is making it through.
      My Controller
      My Check-in Points
        austin
        I'm seeing the same issue with espnow receiving the previous message after the devices have been running for anywhere from couple of hours to a day. I'm using uiflow version 1.9.5 on a M5Stamp and Core2. The project is a home alarm system, I'm only sending 4 bytes of data when a zone is opened/closed or if the alarm is armed or disarmed.
        If I can't find the solution I'm afraid I going to have to ditch uiFlow and try the Arduino API.
        Did you ever figure out the issue?
        Thank You
        Austin
          shichimi
          I have same problem , after some time EspNow recieve callback block returns duplicate message.
          Uiflow 1.10.7 , firmware m5 tough 1.10.6
