    Matrix M5.dis
    SOFTWARE
    6
    10
    18.2k
    • johnwargoJ
      johnwargo
      I just purchased some M5 Atom Matrix devices and I want to start programming the LEDs. Where do I find documentation for the M5.dis API? The sample code does very little and I can't find any reference to M5.dis in the docs I've been able to find.
      John M. Wargo
      Author of Learning Progressive Web Apps (https://learningpwa.com)
      • lukasmaximusL
        Hey are you programming in arduino or uiflow? you can check out these videos to get started
        arduino
        https://www.youtube.com/watch?v=2f4biAfvC_M
        uiflow
        https://www.youtube.com/watch?v=4dr5Y5ssQTk&t=201s
        • johnwargoJ
          johnwargo
          Thanks, but that doesn't answer my question. I'm looking at the sample apps and I see references to M5 methods, and M5.dis but I cannot find reference documentation for them anywhere.
          Where are the reference docs for the M5 SDK? What are the methods, properties, etc. for the M5.dis object?
          John M. Wargo
            Hello John
            Have you seen this? https://github.com/m5stack/M5Atom#display-api-document
            johnwargoJ 1 Reply Last reply Reply Quote 0
            • johnwargoJ
              johnwargo @felmue
              @felmue Thanks, yes, I have - but that's not documentation for M5.dis object, that's documentation for some methods in a utility library that isn't even loaded by the M5 library.
              led-matrix:14:10: error: 'class LED_Display' has no member named 'fillpix'
                 M5.dis.fillpix(CRGB::Black);
              exit status 1
              I'm trying to figure out how to work with the matrix display on the Atom Matrix and I can't find any examples, end to end, that work. I found a reference to M5.dis but I'm just not seeing anything that references it or real examples of how to use it.
              I tried using FastLED which is what the utility/LED_DisPlay.h code uses under the covers, even submitted some PRs today to tighten up that code, but as soon as I make any call to FastLED to update the display or show pixels, the sketch crashes.
              John M. Wargo
              • world101W
                world101
                Not sure why, but the sketch was crashing for me as well, until I commented out the include M5Atom.h and m5.begin lines.
                  Hi John
                  The M5.dis object is defined in M5Atom.h as a member of M5Atom class:
                  class M5Atom
                      LED_DisPlay dis;
                  extern M5Atom M5;
                  For the M5Atom examples to compile I had to add M5Atom and FastLED libraries to the project. (In PlatformIO I can simply drop the two libaries into the lib directory of the project. Not sure how that works with Arduino IDE, sorry.)
                  • johnwargoJ
                    johnwargo @felmue
                    @felmue aaah, OK, I missed that when I looked at the source. Thanks.
                    I'm loading M5Atom.h and FastLED.h and its just not working for me.
                    John M. Wargo
                      stevesch @johnwargo
                      @johnwargo If anyone comes across this and is looking for functioning Arduino/PlatformIO code for the M5 Atom Matrix display, there's some on github here:
                      https://github.com/stevesch/atom-waves
                      • R
                        robalstona
                        You can try neopixel library (probally from adafruit)
