    http request to netatmo fails with error (solved!)
    11 Posts 5 Posters 26.4k Views 1 Watching
      May sound stupid but have you tried
      payload = {'grant_type': 'authorization_code',
      Perhaps your code should be key "grant_type" value authorization_code
      • dblooomD Offline
        dblooom
        thx, but this seems not to be the solution (I tested it anyway). Grant-Type "password" is correct afik.
        ozbkO 1 Reply Last reply Reply Quote 0
        • ozbkO Offline
          ozbk @dblooom
          @dblooom The header option should be like it.
          • dblooomD Offline
            dblooom
            oh, that was wrong, thx. But still get the same error...
            • dblooomD Offline
              dblooom
              Ok, could figure it out. The http-req sends data as JSON but Netatmo needs it as "data". So I could change it in Phyton code but can't do it in blocky.
              @devs: So it would be nice to have two different slots in the http-reqthing: one for json-data and one for data. Or an option to switch it.
              ajb2k3A P 2 Replies Last reply Reply Quote 0
                ajb2k3 @dblooom
                @dblooom please post this as a bug report on the UIFlow github page as this is important enough for immediate attention
                • dblooomD Offline
                  dblooom
                  @ajb2k3 hm thx. But I'm not familiar with github. Maybe you can submit it for me?
                    ajb2k3 @dblooom
                    @dblooom said in http request to netatmo fails with error (solved!):
                    Done.
                      PacQ @dblooom
                      @dblooom Hi. Sorry for resurrecting this topic, but I can't figure it out at all and haven't found any other resources regarding "Netatmo" and M5Stack on the web. I've tried to fix this issue by replacing "json={'grant_type':'password', ...}" with "data={'grant_type':'password', ...}" and also "data=[('grant_type','password'), ... ] and still had lo luck with it.
                      I have no problem getting a correct response when working with Postman or directly with Python, but I'm not able to figure out what's wrong in UiFlow.
                      Would you perhaps have time to elaborate on how you have managed to fix it in "python portion" of the UiFlow if you still remember?
                      Sorry again for the inconvenience.
                      Best regards.
                      • ? Offline
                        A Former User
                        Hi
                        is it possible to share you code ? interest by this code.
                        for me the UIFlow not work with my M5 stack so I use only arduino ide interface.
                        Thx
