    Big Letter Character
    4 Posts 2 Posters 8.0k Views 1 Watching
      Mustafaturgut
      I need to use big character. On Uiflow For core 2 there is only Montserrat48. How can i use bigger character with uiflow? I need 60 or something like it.
      Thank you
        Mustafaturgut
        I have .fon file or .C .H font file. I add these to flash directory and i try to use mu to wrote codes. I need help for the activate codes for that font file. Which code i need to write in my codes to use that font file?
        • m5stackM Online
          Unfortunately, our engineer already test. UIFlow firmware Unicode font used too much memory, so we can't extension more font size support.
          you don't mind use Arduino, you could use this tool to create big size font and compile it with the program
          https://github.com/m5stack/FontCreator
            Mustafaturgut @m5stack
            @m5stack This font maker for Aurdino is it correct? Not for uiflow and there is no way for Uiflow? At least only for numbers... You can add some big font only for numbers.
