    GPS (AT6558) at Thonny editor
    Micropython
    4.7k
      schotek
      I have code in Micropython to communicate with the GPS unit connected to port A (because I use plain Gray M5Stack unit) and using Thonny editor.
      If I upload code directly to the device a run it from the menu, it works well. But if I try to run it directly from Thonny editor (it uses REPL mode I guess), I got this error:
      Unit: Please change unit gps to other grove
      It is very simple code and it looks like this:
      import os
      from m5stack import *
      from m5ui import *
      from uiflow import *
      import unit
      setScreenColor(0x222222)
      gps0 = unit.get(unit.GPS, unit.PORTA)
      label0 = M5TextBox(92, 85, "Text", lcd.FONT_Default, 0xFFFFFF, rotate=0)
      label1 = M5TextBox(92, 70, "Text", lcd.FONT_Default, 0xFFFFFF, rotate=0)
      while True:
        label0.setText(str(gps0.pos_quality))
        label1.setText(str(gps0.satellite_num))
        wait_ms(2)
      Do you have any tips?
        SP3SWJ
        Hi, In GRAY M5STACK unfortunatelly PortA is used for I2C to some internal chip. Sometime GPS not work on Grove Cable.
        Just connect GPS to
        16RX <<< TX White
        17TX >>> Rx Yellow
        And all start working with no problem.
        Example code from Arduino works if You add
        #define RX1 16
        #define TX1 17
        void setup()
        M5.Power.begin();
        GPSRaw.begin(9600, SERIAL_8N1,RX1,TX1);
