    How to make RTC clock with NTP
    UIFlow
    7
    10
    24.6k
    • lilianzL
      lilianz
      How to make RTC clock with NTP Sync for M5StickC in in python (UIflow 1.4.4) ?
      the code below gives an error "RTC' object has no atribute 'ntp_sync"
      import machine
      import utime
      rtc = machine.RTC()
      rtc.ntp_sync(server="hr.pool.ntp.org", tz="CET-1CEST")
      rtc.synced()
      True
      utime.gmtime()
      (2018, 1, 29, 16, 3, 18, 2, 29)
      utime.localtime()
      (2018, 1, 29, 17, 3, 30, 2, 29)
      • lukasmaximusL
        Hey @lilianz I regret to inform you that ntp_sync hasn't been present in the RTC module since firmware v1.2.3 I'm not entirely sure why, but thats the way it is. Perhaps you will find some clues on controlling the RTC from one of the many watch projects on our hackster page https://www.hackster.io/m5stack/projects
        S D 2 Replies Last reply Reply Quote 0
        • R
          raystdenis
          Got tired of waiting for M5Stack MicroPython to support rtc.ntp_sync, so I came up with a simple workaround, assuming you have access to a webserver:
          On your webserver, just create a tiny datetime.php file as follows:
          <html><body>
          <?php echo '[' . getDatetimeNow() . ']';
          function getDatetimeNow() {
          $tz_object = new DateTimeZone('Canada/Pacific');
          $datetime = new DateTime();
          $datetime->setTimezone($tz_object);
          return $datetime->format('Y-m-d\ H:i:s');
          </body></html>
          Change the TimeZone to your own timezone.
          When this PHP code runs, it simply takes the webserver's internal date and time (which should be fairly accurate) and displays the text [yyyy-mm-dd hh:mm:ss]
          Now in your MicroPython code, do the following:
          from micropython import const
          from m5stack import *
          from m5ui import *
          from uiflow import *
          import utime as time
          import machine
          import urequests
          import wifiCfg
          RTC_YYYY = const(0)
          RTC_MM   = const(1)
          RTC_DD   = const(2)
          RTC_HH   = const(4)
          RTC_MN   = const(5)
          RTC_SS   = const(6)
          WIFI_SSID      = 'YourSSID'
          WIFI_PASSWORD  = 'YourPassword'
          URL            = 'http://api.pushingbox.com/pushingbox?devid=v883AAC5A2DE4A5A&location='
          DATETIME_URL   = 'http://stdenissoftware.com/datetime.php'
          # Set internal RTC clock based on calling a URL that returns the current local time
          # as '[yyyy-mm-dd hh:mm:ss]'. Function must be connected to internet.
          # Parameters:
          #   WIFI_SSID: the SSID to connect to
          #   WIFI_PASSWORD: Wifi Password
          #   DATETIME_URL: the URL to call to return the current time
          def setRTC(WIFI_SSID,WIFI_PASSWORD,DATETIME_URL):
            rtc = machine.RTC()
            while wifiCfg.wlan_sta.isconnected() != True:
              wifiCfg.doConnect(WIFI_SSID,WIFI_PASSWORD)
              if wifiCfg.wlan_sta.isconnected() != True:
                time.sleep(1)
              #end if
            #wend
            if wifiCfg.wlan_sta.isconnected():
              #lblWiFi.setText('WiFi Connected')
              try:
                req = urequests.request(method='GET', url=DATETIME_URL,headers='')
                httpData = req.text
                iPos1 = httpData.find("[")
                iPos2 = httpData.find("]")
                if iPos2 > iPos1:
                  DateTime = httpData[iPos1+1:iPos2]
                  YYYY = int(DateTime[0:4])
                  MM   = int(DateTime[5:7])
                  DD   = int(DateTime[8:10])
                  HH   = int(DateTime[11:13])
                  MN   = int(DateTime[14:16])
                  SS   = int(DateTime[17:19])
                  # Set RTC using: Year,Month,Day,WeekDay,Hour,Min,Sec,MS
                  rtc.datetime((YYYY,MM,DD,0,HH,MN,SS,0))
                else:
                  DateTime = ''
                #end if
              except:
                DateTime = ''
            else:
              #lblWiFi.setText('WiFi not connected')
              DateTime = ''
            #end if
            return DateTime
          RightNow = rtc.datetime()
          CurrentYear   = int(newDateTime[RTC_YYYY])
          CurrentMonth  = int(newDateTime[RTC_MM])
          CurrentDay    = int(newDateTime[RTC_DD])
          CurrentHour   = int(newDateTime[RTC_HH])
          CurrentMinute = int(newDateTime[RTC_MN])
          CurrentSecond = int(newDateTime[RTC_SS])
          So, once the RTC is set, it will keep pretty accurate time until the M5Stack gets reset or powered off. Or you can just call the routine every day to resync it. Note that the PHP code is currently set for Canadian Pacific Time.
          Also note that the above URL is my personal webserver - you can use it for quick testing, but not long term please.
          • R
            raystdenis @raystdenis
            Sorry, the last few lines should read:
            CurrentYear   = int(RightNow[RTC_YYYY])
            CurrentMonth  = int(RightNow[RTC_MM])
            CurrentDay    = int(RightNowRTC_DD])
            CurrentHour   = int(RightNow[RTC_HH])
            CurrentMinute = int(RightNow[RTC_MN])
            CurrentSecond = int(RightNow[RTC_SS])
            Sorry, this is my first MicroPython program and just learning it.
            Ray
            • T
              TheAlphaGhost
              Same here. The M5 Docs are a nightmare!!
              On every documentation, the syntax is wrong, and not work correctly!
                I recently uploaded an NTP RTC example for UIFLow 1.7.
                Where has that gone?
                  sj3fk3 @lukasmaximus
                  @lukasmaximus Why is it still not fixed?
                  • D
                    dionw @lukasmaximus
                    @lukasmaximus I'm keen to see this working as well. When do you think it might be possible for the NTP RTC example uiFlow block @ajb2k3 mentioned he had uploaded to be available?
                      ajb2k3 @dionw
                      @dionw said in How to make RTC clock with NTP:
                      Not Sure what happened to it but the example file has been uploaded to github
                      https://github.com/Ajb2k3/UIFlowHandbook/blob/master/NTP_RTC.m5f
                      • D
                        dionw @ajb2k3
                        Thx @ajb2k3 - only that example does not appear to be applicable to the M5StickC.
