    Pa.HUB in m5atom
    4 Posts 3 Posters 8.0k Views 1 Watching
      papanoel
      Hi all. I have one question with the m5 atom. What is the porpuse of being able to choose the Pa.HUB?? If we can not add any other device to the Pa.HUB?
      Thanks in advance.
        Peter @papanoel
        Hallo @papanoel ,
        I had the same problem on M5Stck C. In this link https://community.m5stack.com/topic/2852/not-possible-to-connect-pa-hub-on-m5stack-core2/6 I find a workaround for this problem. It works fine: https://www.peters-bastelkiste.de/m5stick-c-und-atom-units-hinter-pahub-betreiben/ and https://www.peters-bastelkiste.de/m5stick-cplus-als-mehrfach-multimeter/ (in german).
        I hope in the next revision this will be resolved.
        Graetings Peter
        • IAMLIUBOI Offline
          IAMLIUBO
          @papanoel ,
          Thanks for feedback, we will fix it ASAP.
            Peter @IAMLIUBO
            @iamliubo
            Thank you :)
            I just noticed that it is already implemented. Thank you very much for that. It helps me a lot.
