    Sudoku app for M5Paper
    PROJECTS
    7
    12.9k
      murraypaul
      Source available here: https://github.com/murraypaul/M5Sudoku
      M5Sudoku
      Sudoku application for M5Paper
      Can generate uniquely solveable Sudoku puzzles, targetting a given number of clues, to act as a difficulty setting.
      At any point, can validate that the puzzle is still solvable.
      Can mark squares as either a known value, or a set of possible values.
      Can save and reload current state to EEPROM.
      Will automatically shutdown and save state after 5 minutes of inactivity.
      179823
      Notes:
      • Selecting a square in the large grid will display it in the small grid on the right
      • The selected square is highlighted in the large grid
      • You can use the small grid to either set a single known value for the square, or select multiple possible values
      • It may not be possible to generate a uniquely solveable puzzle of the given numbers of clues in the time requested
      • In this situation, the puzzle with the lowest number of clues that still gives a unqiue solution will be returned
      • The fewer target clues you ask for, the longer it will take to generate the puzzle
      • The 'Validate' button will confirm that the puzzle is still uniquely solveable
      • The 'Clue' button will fill in one randon unsolved square
      • Over time the screen may get a bit muddy, due to the fast refresh option used on the EPD screen
      • The 'Validate' button will also do a full screen slow refresh, which will clean up the display
        Hello @murraypaul
        this is very cool. Nicely done.
        When I compile it in PlatformIO I get a couple of errors. I've fixed them and made a pull-request for you to consider.
        Thanks a lot!
        M 2 Replies Last reply Reply Quote 0
          murraypaul @felmue
          @felmue I'll try to get PlatformIO set up and take a look, thanks,
            murraypaul @felmue
            @felmue I've updated the code, it should now compile with no warnings in PlatformIO.
              Hello @murraypaul
              Thank you!
              • IAMLIUBOI
                IAMLIUBO
                @murraypaul ,
                Great, thanks for sharing.
                • E
                  ekalfwonS
                  I've been trying to get this to compile/install using the Arduino IDE and i'm not getting anywhere... Once installed, the M5Paper just continuously reboots, flashing the screen on and off.
                  Watching the serial monitor I see this repeated on each reboot... Any suggestions?
                  Rebooting...
                  M5EPD initializing...OK
                  Guru Meditation Error: Core 1 panic'ed (LoadProhibited). Exception was unhandled.
                  Core 1 register dump:
                  PC : 0x400d7c9f PS : 0x00060330 A0 : 0x800d48ea A1 : 0x3ffb1f10
                  A2 : 0x3ffc19a0 A3 : 0x00000000 A4 : 0xffffffff A5 : 0x3ffc1a78
                  A6 : 0x0001fa40 A7 : 0x00000000 A8 : 0x00000000 A9 : 0x3ffb1ee0
                  A10 : 0x00000000 A11 : 0x00000000 A12 : 0x00000000 A13 : 0x000003c0
                  A14 : 0x0000021c A15 : 0x3f407a74 SAR : 0x00000011 EXCCAUSE: 0x0000001c
                  EXCVADDR: 0x00000000 LBEG : 0x400014fd LEND : 0x4000150d LCOUNT : 0xffffffff
                  Backtrace: 0x400d7c9f:0x3ffb1f10 0x400d48e7:0x3ffb1f40 0x400d5d7e:0x3ffb1f90 0x400e174b:0x3ffb1fb0 0x40088dbd:0x3ffb1fd0
