    COLOR_TCS3472 on Atom Lite cannot find sensor
    PRODUCTS
    3.4k
    • A
      Alban_T
      When I use the example sketch for the color_tcs3472 sensor on my Atom Lite the serial output shows:
      No TCS34725 found ... check your connections
      The sensor is working when I use the same sketch with an Arduino Uno so the problem isn't in the sensor.
      Does anyone have any suggestions on how to troubleshoot this?
      Best regards,
      Alban
        Hello @Alban_T
        the sketch you linked is for M5Stack devices. M5Atom Lite is a bit different. For instance:
        • I assume you modified #include <M5Stack.h> to #include <M5Atom.h>.
        • did you also adapt the M5.begin() call to enable I2C? E.g. M5.begin(true, true, true) - the second true enables I2C on Atom Lite.
        • is your sensor connected to the proper GPIOs? E.g. SDL - GPIO25 and SCL - GPIO21.
        excerpt from M5Atom.cpp as reference:
        void M5Atom::begin(bool SerialEnable , bool I2CEnable , bool DisplayEnable )
        	if( _isInited ) return;
        	_isInited = true;
        	if( I2CEnable )
        		Wire.begin(25,21,10000);
        Hope this helps. If not, feel free to post the full sketch.
        Good luck.
