    1.7.2 uiflow menu speed (core2)
    Bug Report
    3.6k
    • B
      BricoMS
      Hi M5Stack,
      The Core2 uiflow 1.7.2 firmware has following problem:
      Description: The menu for ui flow on the m5core2 (the one to switch applications or go into setup) Its speed is too fast, making it imposible to make a selection on time.
      Version: 1.7.2
      Expected behavior: The time before uiflow starts running the selected mode should take longer so the user can make a selection.
      Tested Hardware: M5stack Core2 for AWS, with defaul base.
      Thanks.
      • B
        BricoMS
        Adding investigation, this seems to happen only if you upload to the core2 an empty project.
