    Can´t get token ATOM EchoSTT
    General
    5
    8
    10.8k
    • A
      antoniopp99
      Hi! I cant get token for ECHO STT on m5 burner. Always get token failed. Check your network status and retry ... this error occurs in any device or network. Any ideas? Thanks!
        Mates28
        I have the same problem and I tried multiple internet connections
        • ZontexZ
          Zontex
          Hey all,
          is the problem still happening? what UIFlow version are you using and what's the OS version?
            Mates28
            @zontex said in Can´t get token ATOM EchoSTT:
            Hey all,
            I'm using MacOS version M5burner 2.2.4 and EchoSTT in it 1.0-en. After the flash, ECHO normally connects to my WiFi, but after clicking on "Get Token" nothing happens for a long time and then it reports this error "Get token failed. Check your network status and retry ..". The internet works for me normally. I've been trying this way for over a week.
            • ZontexZ
              Zontex @Mates28
              @mates28 Hi Mates, i'm checking with our engineers and get back to you. could possibly be a server issue on our side but need to confirm that.
              • P
                plusulli
                It still does not work
                • m5stackM
                  @antoniopp99 said in Can´t get token ATOM EchoSTT:
                  device
                  We have tested it and it works. Where are you located? maybe your area can't access your server normally. you could try to change the network (like use the phone AP) then try again.
                  • P
                    plusulli
                    my area is Germany I can't get a token for Atom Echo and the Timercam it has worked for both in the past
