    M5Stack Official ESP32 Camera Module - Demo, Runtime Error
    PRODUCTS
    16
    48.5k
    • pksuf07P
      pksuf07
      First of all, if I violate any community posting rule, please forgive me because it is my first time.
      I bought two ESP32CAM units (https://www.aliexpress.com/item/M5Stack-Official-ESP32-Camera-Module-Development-Board-OV2640-Camera-Type-C-Grove-Port-3D-Wifi-Antenna/32881414545.html?spm=a2g0s.9042311.0.0.3da24c4dBymjBW) and tested with esp32-cam-demo (https://github.com/igrr/esp32-cam-demo).
      One unit was OK but I have problems with the other unit:
      First of all, flashing was not easy. I made success 1 out of 4~5 tries after I hold down and release reset button (download mode).
      Secondly, the camera was not probed properly. So, I installed the camera again and it probed (detected) ov2640 camera ok. Now, it reboots while it initiating wifi as follows.
      == Error Message ==
      I (497) camera_demo: ESP_WIFI_MODE_STA.[0m
      E (497) wifi: misc_nvs_load 43 ret=4364
      E (497) wifi: wifi_init 1408 ret=4364
      ESP_ERROR_CHECK failed: esp_err_t 0x110c at 0x40107fc1
      file: "C:/msys32/xxx/xxx/esp32-test/esp32-cam-demo-m5cam-right/main/app_main.c" line 417
      func: wifi_init_sta
      expression: esp_wifi_init(&cfg)
      Backtrace: 0x400882e8:0x3ffbaa10 0x40088779:0x3ffbaa30 0x40107fc1:0x3ffbaa50 0x401093b5:0x3ffbab50 0x400d0e4b:0x3ffbabf0
      Rebooting...
      ets Jun 8 2016 00:22:57
      == End of Error Message ==
      Does any one have resolved this issue?
      I requested how I can replace this unit through Aliexpress but haven't got any reply back.
      I am hoping I can fix the issue because it's going to take long time to replace the possibly defective unit.
      Any solution ? Or any recommendation?
      • C
        Calin
        Check the project idf config using make menuconfig option.
        In this situations, a debugger will be very helpful.
        pksuf07P 1 Reply Last reply Reply Quote 0
        • pksuf07P
          pksuf07 @Calin
          @calin
          Appreciate your reply. The problem is that for this new module I do not any other pinouts except USB Type-C and Grove to connect JTAG, SWD, or any other debugging interfaces. I have to confess that I am not expert on this issue but if you know how I can do? I enabled gdb stuff in menuconfig. But I am wondering if I can connect OpenOCD and gdb through it.
          Can you enlighten me?
          Thanks,
          Kyu
          • C
            Calin @pksuf07
            @pksuf07 在 M5Stack Official ESP32 Camera Module - Demo, Runtime Error 中说:
            @calin
            Thanks,
            Kyu
            Check the wifi config on project menuconfig.
            The Jtag connect's to GPIO's 12,13,14,15,RST and GND on ESP32.
            If you really whant to use a Jtag on that one, you can use any FTDI based Jtag and you must solder some wires to ESP32 Jtag pin's...
            • pksuf07P
              pksuf07 @Calin
              @calin
              ![alt text](0_1530052260078_f6b31b03-3156-4615-8f94-d51f3134b6cc-image.png image url)
              I would if the unit is like DevKit but as you can see in above picture. No pinout for soldering. Did you mean soder directly on ESP32 chip pinout?
              I appreciate your attention to my question a lot.
              Kyu
              • 0x1abin0
                0x1abin
                Hi, try prebuilt firmware:
                https://github.com/m5stack/esp32-cam-demo/blob/m5cam/m5cam-firmware.zip
                C pksuf07P D 4 Replies Last reply Reply Quote 0
                • C
                  Calin @0x1abin
                  @bin 在 M5Stack Official ESP32 Camera Module - Demo, Runtime Error 中说:
                  That firmware should do... if the hardware is OK
                  @calin
                  Well... yeah... if you are determined to debug...
                  • pksuf07P
                    pksuf07 @0x1abin
                    @bin
                    Hi Bin,
                    This works. It probed camera good and got connected. Can you enlighten me there is any changes in the source code?
                    I (0) cpu_start: App cpu up.
                    I (361) heap_init: Initializing. RAM available for dynamic allocation:
                    I (368) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
                    I (374) heap_init: At 3FFB9E48 len 000261B8 (152 KiB): DRAM
                    I (380) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM
                    I (386) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
                    I (393) heap_init: At 400907AC len 0000F854 (62 KiB): IRAM
                    I (399) cpu_start: Pro cpu start user code
                    I (193) cpu_start: Starting scheduler on PRO CPU.
                    I (0) cpu_start: Starting scheduler on APP CPU.
                    I (283) camera_demo: Detected OV2640 camera, using JPEG format
                    I (503) camera_demo: ESP_WIFI_MODE_AP
                    I (503) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
                    I (593) phy: phy_version: 3910, c0c45a3, May 21 2018, 18:07:06, 0, 0
                    I (603) camera_demo: wifi_init_softap finished.SSID:M5Cam password:
                    I (603) camera_demo: Open http://192.168.4.1/jpg for single image/jpg image
                    I (613) camera_demo: Open http://192.168.4.1/jpg_stream for multipart/x-mixed-replace stream of JPEGs
                    I (623) camera_demo: Free heap: 142392
                    I (623) camera_demo: Camera demo ready
                    • pksuf07P
                      pksuf07 @Calin
                      @calin
                      Thanks for advice. I feel sorry I do not have skill and equipment to solder ESP32 Chipset pint out for debugging which I would love to learn to .
                      @Bin
                      I will try.
                      • C
                        Calin @pksuf07
                        @calin
                        @Bin
                        I will try.
                        Here is my M5Stack debug setup: a "home made" Jtag, some ESP32 board and a ILI9341 TFT.
                        And M5Stack device running (almost) the same code :)
                        Too bad the actual M5Stack don't have a touchscreen... i can use the touchscreen on the debug "setup" :)
                        • pksuf07P
                          pksuf07 @Calin
                          @calin
                          Appreciated your information and picture.
                          I am already able to configure the debugging setup. I have done it but I could not with ESP32CAM.
                          By the way, it seems to me that you are using platform I/O which I do not use. So, I will try as per your configuration.
                          And I do not have m5stack core and accessory units except ESP32CAM.
                          In fact I am interesting ESP32CAm only if it can handle some real time application because I believe it can off-load some of processing with ESP32, especially by pipelining processing frame while it streaming. For example stereo vision for distance. This is just hobbiest's thought.
                          Thanks,
                          • C
                            Calin
                            I can't debug on M5Stack Core because it use GPIO 14 as TFT CS and that's interfering with Jtag TMS line.
                            That's why i made this setup for debugging.
                            • pksuf07P
                              pksuf07 @Calin
                              @calin
                              Understood. I am sorry I do not have M5Stack core. Only ESP32CAM. I now understand your setup little bit.
                              I should keep in touch with you more to learn from you more.
                              • pksuf07P
                                pksuf07 @0x1abin
                                @bin
                                Hi bin,
                                Can you give little information on the changes or setup I am missing? I tried to make this as STA and giving static ip address. The firmware you uploaded is good for softAP.
                                Thanks,
                                0x1abin0 1 Reply Last reply Reply Quote 0
                                • 0x1abin0
                                  0x1abin @pksuf07
                                  @pksuf07 Hi, This is the ESP32CAM pinout
                                  https://github.com/m5stack/esp32-cam-demo/blob/m5cam/main/Kconfig.projbuild#L44
                                  • D
                                    dda @0x1abin
                                    @0x1abin The prebuilt firmware doesn't work for me either. I get this:
                                    I (362) heap_init: Initializing. RAM available for dynamic allocation:
                                    I (369) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
                                    I (375) heap_init: At 3FFB9E48 len 000261B8 (152 KiB): DRAM
                                    I (381) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM
                                    I (387) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
                                    I (394) heap_init: At 400907AC len 0000F854 (62 KiB): IRAM
                                    I (400) cpu_start: Pro cpu start user code
                                    I (194) cpu_start: Starting scheduler on PRO CPU.
                                    E (306) camera_demo: Camera probe failed with error 0x20001
                                    Faulty device?
