Core2 Port I2C Not Working
I have a grey core and have used the TOF sensor with success, utilizing UI-FLOW. I just got a Core2 and burned UI-Flow into it. When I attach the TOF sensor to port A it appears to not be able to be read on the I2C bus. Any suggestions?
Thanks -
Felix thanks for the suggestion. You were absolutely correct version 1.7.0 resolved the problem.
@se said in Core2 Port I2C Not Working:
Now in 1.7.1.1 this problem was fixed.
