    Problem with RGB led bar for M5stack core 2
    Core2 for AWS
    6.9k
    • V
      vgamlc
      Could someone help me with some example on how to control the RGB led bar for m5stack core 2, I am new to this.
      Thanks in advance.
      • OyczEO
        OyczE @vgamlc
        @vgamlc check this one, so far my Core2 + bottom2 fail big time ..
        https://forum.m5stack.com/topic/2663/core2-uiflow-bottom2-support/6
        • R
          rashedtalukder
          @vgamlc, can you describe what you are wanting to see?
          The Sk6812 (side LED bars) has a few methods you can use (take a look at components/core2forAWS/core2forAWS.h from one of the projects):
          void Core2ForAWS_Sk6812_SetColor(uint16_t pos, uint32_t color);
          void Core2ForAWS_Sk6812_SetSideColor(uint8_t side, uint32_t color);
          void Core2ForAWS_Sk6812_SetBrightness(uint8_t brightness);
          void Core2ForAWS_Sk6812_Show();
          void Core2ForAWS_Sk6812_Clear();
          If I want to set the left LED bar to yellow example, you should put the following into your application:
          Core2ForAWS_Sk6812_SetSideColor(SK6812_SIDE_LEFT, 0xFFFF00);
          Head of the AWS IoT EduKit program and AWS employee. Not an M5Stack employee.
