    cannot open source file "AvailabilityMacros.h" (dependency of "M5EPD.h")
    General
    5.8k
    • G
      gionata
      Just started using Visual Studio Code with the PlatformIO extension to develop a simple app for m5paper starting from the online image sample.
      https://github.com/m5stack/M5EPD_OnlineImage_FixUrl
      If I try debugging, the code does not build:
      Any idea where is this library?
      Any help is appreciated,
      Gionata
      • sodokuS
        sodoku
        @gionata said in cannot open source file "AvailabilityMacros.h" (dependency of "M5EPD.h"):
        AvailabilityMacros.h is a file by Apple. It looks like it's provided by Xcode. Do you have Xcode installed?
          springi
          In Mac Terminal, type
          xcrun --show-sdk-path
          to get the XCode SDK path.
          Add the path using the -I option and additional /usr/include/** to the build_flags option in platformio.ini
          eg.
          build_flags =
          	-I /Library/Developer/CommandLineTools/SDKs/MacOSX10.15.sdk/usr/include/**
          found solution on some japanese blog
