    M5StickC Joystick+ESP32 robot+Protocol Buffers (nanopb)+3dprint
    1 Posts 1 Posters 4.4k Views 1 Watching
    • hpsaturnH Offline
      hpsaturn
      AIRobot
      ESP32 robot platform, the idea is join it with a MaxiPy RISC-V camera. For now the current development works with a M5StickC Joystick hat that controlling the robot via UDP using protobuf (nanopb). In the robot it use a simple ESP32 board.
      GitHub
      TODO
      • Platformio project (two sources)
      • UDP channel settings in preferences lib
      • nanopb (protocol buffers implementation) for joystick messages
      • separated OTA (joystick and robot)
      • MQTT channel ?
      • SPI connection to MaxiPy nano camera
      • Push AI models via proto
      • Auto navegation
      • Seek and destroy objects
      Firmware
      You can build it with Arduino IDE renaming the main files to .ino, but it is more easy if you use PlatformIO, with a simple command you upload both, Joystick and Robot.
      pio run --target upload
      Please check the right USB ports on platformio.ini file.
      After the first upload, you could comment the robot and joystick blocks in platformio.ini and uncomment the OTA blocks for upload via WiFi without USB.
      Usage
      Turn on the robot, then the joystick, when the joystick detect the robot, push the M5 button for some seconds for pair. For turn off the joystick press again the M5 button.
      DIY Robot demo
      For the instructions and more details here.
      Youtube demo
