    Accessing decoded JSON array
    6 Posts 5 Posters 13.5k Views
      PhilG1300
      I am new to using UIFlow, but not to programming.
      I am using UIFlow on my M5Stack project.
      I am having difficuly in accessing a JSON decoded array.
      Within the Python code I have a snippet of code:-
      Decoded_Packet = json.loads(Packet)
      Decoded_Location = Decoded_Packet["location"]
      Which works in my application, but it won't change to the UIFlow - Blockly representation, nor save and load correctly.
      So my question in Blockly what is the equivalent of:-
      or
      Decoded_OutTemp = Decoded_Packet["stats]["current"]["outTemp"]
      Which work in the Python coding.
      Regards
      Phil.
      • sodokuS Offline
        sodoku
        You should be able to use the "get key in map" block from "map"
        https://docs.m5stack.com/#/en/uiflow/data_structure?id=map
        Get key location from map Decoded_Packet
          PhilG1300 @sodoku
          @sodoku
          Yes your answer is correct, I have just found the answer just before you replied!!
          See attached screenshot.
          Many thanks for the advice.
          Regards
          Phil
          K 1 Reply Last reply Reply Quote 1
            Kombistack @PhilG1300
            @philg1300
            Thanks Phil, this was very helpfull for me too.
              rmorgan @Kombistack
              @kombistack Im trying to do something similar to this. I'm subscribing to an AWS IOT topic which is publishing a JSON. I can receive the whole message but in trying to extract one field from the JSON its not returning anything. Pic below
                ajb2k3 @rmorgan
                @rmorgan please dont double post.
