    M5 stick C wont turn on am i missing something?
    15 Posts 11 Posters 46.3k Views 2 Watching
      heybin
      if some firmware in stickc, please connect g0 to 3.3V, next insert usbC,it will work well
        heybin
        https://docs.m5stack.com/#/en/faq q9
        • world101W Offline
          world101 @heybin
          @heybin said in M5 stick C wont turn on am i missing something?:
          Though this does work, I'm curious to know if you are working on a real fix via a firmware update.
            heybin
            sorry, this is caused by the battery voltage being too low(not booting for a long time). there is no way to solve it through the program,
              cncninja
              So i have a dead on arivel M5stick C and my m5 fire does not support the usb modual i bought to add usable I/O.... not really loving this..
                jpilarski
                I just wanted to mention if you charge the m5stickc using a usb psu such as what you use to charge your phone it seems to charge the stickc battery and it turns on if you give it a few minutes. Not sure if this might be attributed to the usb output voltage on my computer not being stable but this always works for me. On the usb psu the voltage was 5.01v and on the laptop it was 5.22v so perhaps the overvoltage is an issue. I have 3 or 4 stickc devices and on a couple of them I always have to charge them first before they will boot.
                • MDARM Offline
                  MDAR
                  Hi
                  Is there any news on this subject?
                  I've got 4 X M5stickC units, with 3 being "dead on arrival"
                  Plugging them into my laptop brings them to life, but only 1 stays on when the usb power is removed.
                  I loaded this example script to get the Battery & supply voltages
                  https://github.com/m5stack/M5StickC/blob/ce1af7500b9d2370983c778266e1ea941ac9f2d8/examples/Advanced/AXP192/PowerWake/PowerWake.ino
                  The good one shows about 4v from the battery and 4.99v on the usb power.
                  The other three show
                  Battery ~0.003v
                  I've tried the G0 to GND trick, but that didn't work.
                  I did go looking for a new firmware, as mentioned above, but the link is dead.
                  Any help would be most welcomed.
                  • N Offline
                    nicolas @MDAR
                    @mdar thanks for pointing to this script, I have the same issue : 0v on battery !
                    • ZontexZ Offline
                      Zontex
                      Hi @nicolas @MDAR if you guys still encounter this issue please contact me at roni@m5stack.com to resolve it, thank you!
                      • E Offline
                        Efried @Zontex
                        @zontex After a longer charging my M5stick works, but it is not possible to switch it into USB or WLAN mode, so I may upload code.
                        • R ren072 referenced this topic on
