    req.status_code
    5 Posts 2 Posters 7.3k Views
    • W Offline
      Wolli01
      req = urequests.request(method='GET', url='http://xxx.de/Datum.txt')
      print(str(req.status_code))
      The status code is displayed on the first pass, but not on the second pass. What could be the reason for this?
      • ZontexZ Offline
        Zontex
        Hello, what pass are you referring to? could you please provide the complete code including what Core module are you trying to run it on and the result you are getting? please use the ``` quotes when you write code such as:
        • W Offline
          Wolli01
          Module is Core2.
          It runs in a loop While True:
          On the first run, everything runs correctly.
          From the second run on, the status code is no longer displayed. It is simply skipped!
          • ZontexZ Offline
            Zontex @Wolli01
            @wolli01 can you please attach a complete code or if it's UIFlow could you attach a screenshot of your blocks? the python code will also help.
            • W Offline
              Wolli01
              Update der Settingdaten holen---------------------------------------
                  if (Verbindung) == 1 and wifiCfg.wlan_sta.isconnected(): #Nur bei bestehender Internet Verbindung
                      print("-----------------------------------------------")
                      print("Überprüfe ob es eine Online-Setting Datei gibt")
                      try:
                          try:
                            req = urequests.request(method='GET', url=settings.Gateway+'onlinesettings.txt')
                            print('onlinesettings.txt wurde auf vorhandensein überprüft')
                            time.sleep(1)
                          except:
                            print('onlinesettings.txt ist nicht vorhanden')
                          if (req.status_code == 200) :
                              print('onlinesettings Uebertragung OK')
                              if (ssd1306) == 1:
                                  if (settings.Display) == 1:
                                      lcd.print("Online Update, Setting erfolgt...",0,170,0xb8b8b8)
                              time.sleep(1) #Warte 1 Sekunden
                              with open('/sd/settings.py', 'w') as updatefile:
                                  updatefile.write(req.text)
                              updatefile.close()
                              print('onlinesettings wurde neu erstellt')
                              time.sleep(1)
                              #Datei wieder löschen-------------
                              req = urequests.request(method='GET', url=settings.Gateway+'killsettings.php')
                              print('Setting Datei wurde auf dem Server wieder geloescht')
                              time.sleep(1)
                              Setting_Online_Update = 1
                          else:
                              print('Keine Setting Datei vorhanden!')
                              print("-------------------------------------------")
                      except Exception as e:
                          print('Fehler!')
                          print(e)
                  # On Off Einstellungen holen---------------------------------------
                      print("Überprüfe ob übers Internet ausgeschaltet wird")
                      try:
                          try:
                            req1 = urequests.request(method='GET', url=settings.Gateway+'onoff.txt')
                            print('onoff.txt wurde auf vorhandensein überprüft')
                            print(str(req1.status_code))
                            time.sleep(1)
                          except:
                            print('onoff.txt ist nicht vorhanden')
                            if (req1.status_code == 200) :
                                 print('onoff Uebertragung OK')
                                 OnOff = 0 # An Aus Schalter = Aus
                                 req2 = urequests.request(method='GET', url=settings.Gateway+'killpoweronoff.php')
                                 print('On-Off Datei wurde auf dem Server wieder geloescht')
                                 time.sleep(1)
                            else:
                                 print('Keine On-Off Datei vorhanden!')
                          print('Fehler!')
                          print(e)
