microWebSrv2 on M5atom lite with micropython
I'm trying to install the web server microWebSrv2 on a M5atom lite.
github microWebSrv2Has anyone done this before without freezing?
Would be grateful for any hint.I copied the files with ampy to the m5atom lite, here is the file structure on the M5atom lite:
/ConnectWiFi.py
/MicroWebSrv2/init.py
/MicroWebSrv2/httpRequest.py
/MicroWebSrv2/httpResponse.py
/MicroWebSrv2/libs/XAsyncSockets.py
/MicroWebSrv2/libs/XAsyncSocktes.py
/MicroWebSrv2/libs/urlUtils.py
/MicroWebSrv2/microWebSrv2.py
/MicroWebSrv2/mods/PyhtmlTemplate.py
/MicroWebSrv2/mods/WebSockets.py
/MicroWebSrv2/webRoute.py
/SSL-Cert/openhc2.crt
/SSL-Cert/openhc2.key
/boot.py
/img/microWebSrv2.png
/lib/urequests.py
/main.py
/www/favicon.ico
/www/index.html
/www/pdf.png
/www/style.css
/www/test.pyhtml
/www/wschat.html
/www/wstest.htmlAnd run into this error when booting:
Connection successful
('192.168.1.46', '255.255.255.0', '192.168.1.1', '192.168.1.1')
running on M5atom lite--------------------------- - Python pkg MicroWebSrv2 - - version 2.0.6 - - by JC`zic & HC2 - ---------------------------I (6206) modsocket: Initializing
- [@WebRoute] GET /test-redir
- [@WebRoute] GET /test-post (TestPost1/2)
- [@WebRoute] POST /test-post (TestPost2/2)
File "main.py", line 153, in <module>
File "MicroWebSrv2/microWebSrv2.py", line 136, in LoadModule
MicroWebSrv2Exception: Cannot load module "WebSockets".
MicroPython v1.13 on 2020-09-02; TinyPICO with ESP32-PICO-D4
Type "help()" for more information.this is raised by this code in MicroWebSrv2/microWebSrv2.py:
# ------------------------------------------------------------------------@staticmethod def LoadModule(modName) : if not isinstance(modName, str) or len(modName) == 0 : raise ValueError('"modName" must be a not empty string.') if modName in MicroWebSrv2._modules : raise MicroWebSrv2Exception('Module "%s" is already loaded.' % modName) try : modPath = MicroWebSrv2.__module__.split('microWebSrv2')[0] \ + ('mods.%s' % modName) module = getattr(__import__(modPath).mods, modName) modClass = getattr(module, modName) if type(modClass) is not type : raise Exception modInstance = modClass() MicroWebSrv2._modules[modName] = modInstance return modInstance except : raise MicroWebSrv2Exception('Cannot load module "%s".' % modName) -
It's probably a typo. I think there should be a / on the line instead of .
Instead:
('mods.%s' % modName)i think it should be:
('mods/%s' % modName)or
('mods\\%s' % modName)
